The functions ESP.getHeapStats() and ESP.getFreeContStack() have come in handy, but something seems a little weird at times. There are six ESP8266s running the same exact program, with exactly the same hardware, but each reports different memory usage. I'd expect consistency, but I'm getting different results from each one, running at the same time, on the same network.
ESP.getFreeContStack is fairly consistent in that it never changes on any given device, even though it might be different from one device to the next. I have 2500 to 2600 bytes free on the stack, so I'm not too worried about that, but more confused about why it's not the same from one device to the next.
getHeapStats drives me nuts. I can understand the purpose of reporting how much free heap is available, what's the largest block size that can be allocated, and what's the fragmentation. And I get that I'm supposed to keep fragmentation under 50%. What I don't get is that one device is reporting 100% fragmentation, and that the maximum free block size is over 32,500, when at the same time it is reporting free heap of under 26,000. And with that kind of fragmentation I would expect connection issues at the very least, since it connects and disconnects to the WiFi network constantly throughout the day. But it continues to do its thing, and it seems to have no issues both connecting as a station, and acting as an AP so I can check its operation locally.
I guess my question is really, how accurate is the getHeapStats() function? It is reporting bogus numbers, and not the same numbers on identically flashed devices. The max free block size should never be more than the reported free total. And it jumps to 100% fragmentation within 2 minutes of booting.
Here is the code I'm running. It will run on just an ESP8266 without anything attached, including no DS18B20s or PCF8544s. As long as it can connect to a valid AP it is happy. Not consistent, memory reporting-wise, but running. Comments are abreviated here.
* The IDE options for this device are:
* Board: LOLIN(WENOS) D1 R2 & mini
* Upload Speed: "921600"
* CPU Frequency: "80 Mhz"
* Flash Size: "4MB (FS:1MB OTA:~1019KB)"
* Debug port: "Disabled"
* Debug Level: "None"
* LwIP Variant: "V2 Lower Memory"
* VTables: "Flash"
* Exceptions: "Legacy (new can return nullptr)"
* Erase Flash: "Only Sketch"
* SSL Support: "All SSL ciphers (most compatible)"
* The library versions used by this program are:
* Wire at version 1.0
* ESP8266WiFi at version 1.0
* ESP8266HTTPClient at version 1.2
* ESP8266WebServer at version 1.0
* async-mqtt-client at version 0.8.2
* ESPAsyncTCP at version 1.2.0
* OneWire at version 2.3.5
* DallasTemperature at version 3.8.0
* Modbus-Master-Slave-for-Arduino
* Time at version 1.6 in folder
* Timezone at version 1.2.4
* EEPROM at version 1.0
#include <Wire.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
// AsyncMqttClient is used instead of PubSub, because it allows for QOS 2, and seems to work more reliably
#include <AsyncMqttClient.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include "ModbusRtu.h" // Used for reading other devices with the modbus protocol over RS485
// The standard time functions, including one for timezones.
#include <TimeLib.h>
#include <Timezone.h>
bool time_was_set = false;
uint16_t time_offset;
#include <EEPROM.h>
modbus_t telegram;
const char VERSION[] = __DATE__ " " __TIME__;
#define WIFI_SSID "my_ssid"
#define WIFI_PASSWORD "the_ssid_password"
#define WEBNAME "X"
#define MQTT_HOST IPAddress(192, 168, 0, 104)
#define MQTT_PORT 1883
// This program (device) publishes to the "Zones" subject on the mqtt server, versus the use of "AHU" by the air handlers.
#define MQTT_NAME "Zones"
// Poll once every 600 seconds, or 10 minutes
#define TIME_BETWEEN_POLLING 600000
// 1800 seconds is half an hour
#define BLAST_INTERVAL 1800000
// The I2C address of the connected PCF8574 (if it is there)
#define PCF8574_I2C 0x20
// Check the PCF8574 every 15 seconds
#define PCF8574_INTERVAL 15000
// The I2C address of the PCF8591
#define PCF8591_I2C 0x48
// Check the PCF8591 once every minute
#define PCF8591_INTERVAL 60000
// There are at most 10 devices, and each device has 30 registers we are interested in. Up to 10 DS19B20s can be read.
#define MODBUS_DEVICES 10
#define MODBUS_REGISTERS 30
#define DS18B20_DEVICES 10
// MILLIS_MAX is the trip point for rebooting this device, due to weird problems connecting in the production environment after a few days.
// It will boot itself if the current millis() value is higher than this number, and it's 00:30 in the morning.
#define MILLIS_MAX 172800000
// The next few lines are used for the local timezone, since web servers supply world time. The state's web server is a reliable choice.
#define HTTP_TIME_SOURCE "http://mn.gov"
int last_hour; // Simply used to limit how often the address is checked for
HTTPClient http;
WiFiClient client;
ESP8266WebServer server(80); // set the web server to port 80
AsyncMqttClient mqttClient;
Modbus modbusClient(0,0,0); // this is a client (meaning it commands other devices) and uses RS-232, not toggling RS485 which it uses anyway
uint16_t **registers; // This is where the data retrieved from modbus devices is stored
uint16_t **last_registers; // Used to compare values so only updates are send, not everything
uint8_t modbus_state; // Current modbus state, from idle, to requesting, to receiving responses
uint8_t modbus_slave; // Which slave are we talking to on modbus
unsigned long modbus_wait; // Time between modbus requests
OneWire oneWire(D5); // The DS18B20s are connected to D5 on the Wemos
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature ds18b20s(&oneWire);
bool pcf8574Found = false; // There is a PCF8574 that we can read the status of the pins from
bool pcf8591Found = false;
char my_ssid[12]; // The SSID is generated from the last 3 bytes of this devices MAC address, so it can be used as a web server
uint32_t request_wait; // This is used to control when polling takes place, and is a millisecond value.
uint32_t blast_time; // When the last forced mqtt update took place.
uint32_t PCF8574_wait; // The next time the PCF8574 was checked, since its on a different schedule than other devices
uint32_t PCF8591_wait; // The next time the PCF8591 was checked, since its on a different schedule than other devices
uint32_t read_time; // Only used to show on the web status page how long ago the readings were taken
String wifi_ssid; // The SSID of the local guest network in the building
String wifi_password; // The password for the above SSID
String WebName; // The WebName variable has the name of the external web server used as a fallback for finding the mqtt address.
byte mac_address[8]; // The unique address of this device, used to tell who is sending data and as the SSID for web access.
IPAddress mqtt_host; // This is used for the IP address of the mqtt server to connect to.
IPAddress apIP(192, 168, 4, 1); // The local address of this device when accessed through the web interface.
float temperature[DS18B20_DEVICES];
uint8_t lastPCF8574Value; // Used for comparing if any of the lines changed on the PCF8574
float lastPCF8591Value[4];
// QUEUE_WIDTH is the maximum size of an mqtt packet, and is a fixed length for this table
// QUEUE_MAX is the maximum number of entries that can be queued to be transmitted via mqtt
// QUEUE_ARRAY is the byte size of the queue table used for all of the queue entries.
// Note that the size of this table really impacts dynamic memory in the Wemos, and reduces space for local variables.
// Think carefully about the maximum number of queued entries.
#define QUEUE_WIDTH 128
// Warning - If QUEUE_MAX is too big, then the heap isn't big enough for OTA updates. For example, 250 fails, but 200 works.
#define QUEUE_MAX 100
#define QUEUE_ARRAY QUEUE_WIDTH * QUEUE_MAX
// For the queue, malloc is used instead of reserving space here, or the heap just gets too big
char *queue; // The global queue where all messages end up before being sent to the mqtt server
uint16_t queue_pos;
uint8_t queue_len;
// The eeprom information is used to store the connection information in the EEPROM on this device, so it can
// survive after a reboot or firmware update.
struct EEPROMStruct {
char validate[6] = ""; // will have the word 'valid' when it is valid
char ssid[20] = "";
char password[20] = "";
IPAddress mqtt = IPAddress(0, 0, 0, 0);
char webname[64] = "";
} eeprom_data;
// The next two variables are used for obtaining the time from a trusted external web page.
const char * headerKeys[] = {"date", "server"} ;
const size_t numberOfHeaders = 2;
// And this string is used for OTA updates of this program.
const char* serverIndex = "<form method='POST' action='/updateOTA' enctype='multipart/form-data'><input type='file' name='update'><input type='submit' value='Update'></form>";
//========================================================================// A small procedure to try to clean up memory leaks
struct tcp_pcb;
extern struct tcp_pcb* tcp_tw_pcbs;
extern "C" void tcp_abort (struct tcp_pcb* pcb);
void tcpCleanup ()
while (tcp_tw_pcbs != NULL)
tcp_abort(tcp_tw_pcbs);
//========================================================================// The setup() procedure takes care of reading the eeprom for any stored data, like the
// connection information and the address of the mqtt server, along with setting up the
// time, intializing the variables used during the loop() procedure, and getting the server
// side setup in case anything needs to be changed on the fly.
void setup()
char ts[128];
uint8_t i,j;
uint8_t sensor_address[8];
WiFi.macAddress(mac_address); // get the mac address of this chip to make it unique in the building
sprintf(my_ssid,"%02X%02X%02X",mac_address[3],mac_address[4],mac_address[5]); // Use the hex version of the MAC address as our SSID
WiFi.softAP(my_ssid, "87654321"); // Start the access point with password of 87654321
WiFi.persistent(false); // Only change the current in-memory Wi-Fi settings, and does not affect the Wi-Fi settings stored in flash memory.
Serial.begin(9600); // All serial communications are at 9600,which is fine for what we are doing.
Serial.setRxBufferSize(256); // crank up the size of the RX buffer
pinMode(D6,INPUT_PULLUP); // used for 1-wire
// Allocate memory for the queue at this time. The queue is a global variable, access by multiple procedures.
queue_pos = 0;
queue_len = 0;
queue = (char *)malloc(QUEUE_ARRAY * sizeof(char));
if (queue == NULL)
Serial.print("Failed to allocate the queue.\r\n");
add_to_queue((char *)"R|000|Booting........"); // Let the other end know we had to boot.
// Allocate memory for the modbus registers. This is the same as uint16_t registers[MODBUS_DEVICES][MODBUS_REGISTERS];
registers = (uint16_t **)malloc(sizeof(uint16_t *) * MODBUS_DEVICES);
last_registers = (uint16_t **)malloc(sizeof(uint16_t *) * MODBUS_DEVICES);
for (i=0; i < MODBUS_DEVICES; i++)
registers[i] = (uint16_t *)malloc(MODBUS_REGISTERS * sizeof(uint16_t));
last_registers[i] = (uint16_t *)malloc(MODBUS_REGISTERS * sizeof(uint16_t));
// reset the holding registers to 0 to make sure they start clean
for (j = 0; j < MODBUS_DEVICES; j++)
for (i = 0; i < MODBUS_REGISTERS; i++)
registers[j][i] = 0;
last_registers[j][i] = 0; // used for comparing current to previous to limit updates
ESP.wdtFeed();
EEPROM.begin(512); // try to get the connection info from EEPROM
EEPROM.get(0,eeprom_data);
if (!strcmp(eeprom_data.validate,"valid")) // Is there a valid entry written in the EEPROM of this device
wifi_ssid = String(eeprom_data.ssid);
wifi_password = String(eeprom_data.password);
mqtt_host = eeprom_data.mqtt;
WebName = String(eeprom_data.webname);
else // Default to the defines if the EEPROM has not yet been programmed.
wifi_ssid = WIFI_SSID;
wifi_password = WIFI_PASSWORD;
mqtt_host = MQTT_HOST;
WebName = WEBNAME;
EEPROM.end();
if (!ScanForWifi()) // This is a fallback because constantly remembering to change the EEPROM is a pain.
wifi_ssid = "my_ap";
wifi_password = "my_ap_pw";
mqtt_host = IPAddress(192, 168, 0, 104);
mqttClient.setServer(mqtt_host, MQTT_PORT); // Set the name of the mqtt server.
server.on(F("/config"), handleConfig); // if we are told to change the configuration, jump to that web page
server.on(F("/"), handleStatus); // The most basic web request returns the status information
// The update code is for doing OTA updates of this program. Only /update is called by users. The /updateOTA
// code is called in the background, never directly by the users.
server.on(F("/update"), HTTP_GET, []()
server.sendHeader("Connection", "close");
server.send(200, "text/html", serverIndex);
server.on(F("/updateOTA"), HTTP_POST, []()
server.sendHeader(F("Connection"), "close");
server.send(200, F("text/plain"), (Update.hasError()) ? "FAIL" : "OK");
delay(1000); // Show it for 1 second, then restart the ESP8266 using a software command
ESP.restart();
HTTPUpload& upload = server.upload();
if (upload.status == UPLOAD_FILE_START)
uint32_t maxSketchSpace = (ESP.getFreeSketchSpace() - 0x1000) & 0xFFFFF000;
Update.begin(maxSketchSpace);
if (upload.status == UPLOAD_FILE_WRITE)
Update.write(upload.buf, upload.currentSize);
if (upload.status == UPLOAD_FILE_END)
Update.end(true);
delay(1);
server.begin(); // Start listening for connections to this devices AP. Most of the time it's not needed, but helpful...
ESP.wdtFeed();
ds18b20s.begin(); // Start the sensors
Wire.setClock(100000L); // Only use a 100k clock frequency, the PCF8591 can't handle a higher speed
Wire.begin();
Wire.beginTransmission (PCF8574_I2C); // The address of the PCF8574
if (Wire.endTransmission () == 0)
pcf8574Found = true; // We did find a PCF8574 on the I2C bus, and will use it to read external binary events
lastPCF8574Value = 0; // this forces a transmit on the first pass
Wire.beginTransmission(PCF8574_I2C);
Wire.write(0xff);
Wire.endTransmission();
ESP.wdtFeed();
delay(50);
Wire.beginTransmission(PCF8591_I2C); // The address of the PCF8591
pcf8591Found = true; // We did find a PCF8591 on the I2C bus, and will use it to read external analog voltages
lastPCF8591Value[0] = 6.1; // this forces a transmit on the first pass
lastPCF8591Value[1] = 6.1;
lastPCF8591Value[2] = 6.1;
lastPCF8591Value[3] = 6.1;
PCF8574_wait = millis() + PCF8574_INTERVAL; // Check in 15 seconds
PCF8591_wait = millis() + PCF8591_INTERVAL + (PCF8574_INTERVAL / 2); // Offset this interval from the PCF8574
getTimeFromHttp(); // get the time
last_hour = hour();
// This next chunk of code just gets the DS18B20s past the default 85C stage
ds18b20s.requestTemperatures();
oneWire.reset_search();
j = 0;
if (oneWire.search(sensor_address))
do
ds18b20s.getTempC(sensor_address); // The temperature isn't needed, it just has to be read during setup
j++;
delay(1);
} while (oneWire.search(sensor_address));
for (i = 0; i < DS18B20_DEVICES; i++) // temperature variable is just used for DS18B20s, allowing for DS18B20_DEVICES of them on this device
temperature[i] = 0.0;
modbusClient.begin( 9600 ); // begin the ModBus object.
modbusClient.setTimeOut( 2000 ); // if there is no answer in 2 seconds, roll over to the next
modbus_wait = millis() + 60000; // wait 60 seconds from now before doing the first poll over modbus
modbus_state = 0;
modbus_slave = 0;
request_wait = millis() + TIME_BETWEEN_POLLING + 30000; // offset the normal requests by an additional 30 seconds
blast_time = millis() + 120000; // wait 2 minutes, then send everthing
read_time = millis(); // Realistically, the time since the first reboot (initially)
time_offset = mac_address[5] * 128; // Create a random interval for this device, based on its MAC address
delay(100);
ESP.wdtFeed();
mqttClient.setClientId(my_ssid); // Used to keep things runnng with QOS 2
// This is the end of the setup routine. Posting the VERSION helps identify that everything really is at the same version throughout the building.
sprintf(ts,"R|%03ld|Booted V.%s",(millis() + 499) / 1000,VERSION);
add_to_queue(ts); // tell the mqtt server that this device is up and running. It isn't needed, but helpful.
sprintf(ts,"R|000|Boot reason was:%s",ESP.getResetReason().c_str());
add_to_queue(ts);
char ts1[45];
uint32_t heap_free;
uint16_t heap_max;
uint8_t heap_frag;
ESP.getHeapStats(&heap_free, &heap_max, &heap_frag);
sprintf(ts1,"R|000|Free heap is %ld",(long int)heap_free);
add_to_queue(ts1);
sprintf(ts1,"R|000|Heap fragmentation is %d%%",heap_frag);
add_to_queue(ts1);
sprintf(ts1,"R|000|MaxFreeBlockSize is %d",heap_max);
add_to_queue(ts1);
sprintf(ts1,"R|000|getFreeContStack is %ld",ESP.getFreeContStack());
add_to_queue(ts1);
xmit_the_queue(); // xmit_the_queue() actually connects to the network, connects to the mqtt server, and sends the queued up data.
//========================================================================// Pull the date and time using an HTTP request. This is because the NTP port is blocked
// on the guest network that this system runs on. It is annoying, but easier just to use
// the method of getting the time from a trusted web page.time_t getTimeFromHttp()
int httpCode;
String headerDate;
time_t tt;
tt = 0;
add_to_queue((char *)"R|000|Getting the time");
connectToWifi();
if (WiFi.status() != WL_CONNECTED) // If we couldn't connect through WiFi, then there's no point in continuing.
WiFi.disconnect();
return 0;
ESP.wdtFeed();
http.begin(client,HTTP_TIME_SOURCE); // A generally reliable place to get the date and time
http.setReuse(false);
http.collectHeaders(headerKeys, numberOfHeaders); // Just look at the headers
httpCode = http.GET();
ESP.wdtFeed();
if (httpCode > 0)
headerDate.reserve(35);
headerDate = http.header("date"); // We only want the date and time from the headers
// headerDate looks like Sat, 19 Oct 2019 06:29:57 GMT
tt = timeElements(headerDate.c_str()); // set the date and time using what we got from the http request
add_to_queue((char *)"R|000|Got the time");
http.end(); // We are done with our HTTP request for about 24 hours
delay(100);
WiFi.disconnect();
delay(100);
tcpCleanup();
return tt;
//========================================================================// Parse the printable version of the date and time we got through HTTP into the appropriate
// format for setting the date and time within the Arduino program. This takes a string
// value from an HTTP header.
time_t timeElements(const char *str)
tmElements_t tm;
char t[80];
int Year, Month, Day, Hour, Minute, Seconds, Wday ;
int j;
// An example of a time string to convert is - Sat, 19 Oct 2019 06:29:57 GMT
char delimiters[] = " :,"; // Used to separate the date and time fields
char* valPosition;
Year = 1970;
Month = 1;
Day = 1;
Hour = 0;
Minute = 0;
Seconds = 0;
Wday = 1;
// US Central Time Zone (Chicago)
// This next line sets the correct time offset for the start of Central Daylight Time, on the second Sunday of March at 2am
TimeChangeRule myDST = {"CDT", Second, Sun, Mar, 2, -300}; // Daylight time = UTC - 5 hours
// and the mySTD variable is set for Central Standard Time, which starts the first Sunday in November
TimeChangeRule mySTD = {"CST", First, Sun, Nov, 2, -360}; // Standard time = UTC - 6 hours
Timezone myTZ(myDST, mySTD);
strcpy(t,str);
valPosition = strtok(t, delimiters);
j = 0;
while(valPosition != NULL){
switch(j) {
case 0: // Convert day of week into the proper Wday format.
if (!strcmp(valPosition,"Sun")) Wday = 1;
if (!strcmp(valPosition,"Mon")) Wday = 2;
if (!strcmp(valPosition,"Tue")) Wday = 3;
if (!strcmp(valPosition,"Wed")) Wday = 4;
if (!strcmp(valPosition,"Thu")) Wday = 5;
if (!strcmp(valPosition,"Fri")) Wday = 6;
if (!strcmp(valPosition,"Sat")) Wday = 7;
break;
case 1: // Convert the day of the month into an integer.
Day = atoi(valPosition);
break;
case 2: // Convert the month name into a simple integer.
if (!strcmp(valPosition,"Jan")) Month = 1;
if (!strcmp(valPosition,"Feb")) Month = 2;
if (!strcmp(valPosition,"Mar")) Month = 3;
if (!strcmp(valPosition,"Apr")) Month = 4;
if (!strcmp(valPosition,"May")) Month = 5;
if (!strcmp(valPosition,"Jun")) Month = 6;
if (!strcmp(valPosition,"Jul")) Month = 7;
if (!strcmp(valPosition,"Aug")) Month = 8;
if (!strcmp(valPosition,"Sep")) Month = 9;
if (!strcmp(valPosition,"Oct")) Month = 10;
if (!strcmp(valPosition,"Nov")) Month = 11;
if (!strcmp(valPosition,"Dec")) Month = 12;
break;
case 3: // Convert the year being passed into an integer.
Year = atoi(valPosition);
break;
case 4: // Convert the printed hour into an integer.
Hour = atoi(valPosition);
break;
case 5: // Convert the minute.
Minute = atoi(valPosition);
break;
case 6: // An finally, convert the seconds passed into an integer.
Seconds = atoi(valPosition);
break;
j++; // Look at the next position in the string
//Here we pass in a NULL value, which tells strtok to continue working with the previous string
valPosition = strtok(NULL, delimiters); // Use the strtok function to break the string into pieces
tm.Year = Year - 1970; // Use the UNIX epoch since it is an offset
tm.Month = Month; // Setup the rest of the time values
tm.Day = Day;
tm.Hour = Hour;
tm.Minute = Minute;
tm.Second = Seconds;
tm.Wday = Wday;
ESP.wdtFeed();
setTime(myTZ.toLocal(makeTime(tm))); // Call the myTX class to convert the date and time to the correct timezone, including daylight savings.
return makeTime(tm);
//========================================================================// Search for the desired access point, and if it is found, return 1
uint8_t ScanForWifi()
int n = WiFi.scanNetworks(); // Do a simple network check to see what's available.
if (n == 0)
; // No wifi networks were found
return(0);
for (int i = 0; i < n; ++i)
if (wifi_ssid == WiFi.SSID(i)) // Check to see if the SSID we are supposed to connect to has been found by the scan
return(1);
return(0);
//========================================================================// Connect to the local guest network for long enough to either get the time, or to transmit
// a mqtt packet to the server. Realistically, this program does a connection about every
// 30 minutes, maybe more often if it is monitoring something that changes frequently.
void connectToWifi()
uint8_t i;
if (WiFi.status() == WL_CONNECTED)
return; // No point in connecting if we already are...
delay(50);
WiFi.begin(wifi_ssid, wifi_password);
i = 0;
while (WiFi.status() != WL_CONNECTED && i < 240) // Need to keep looking for about 15 seconds, because, yes, it can take that long to connect
i++;
delay(62);
ESP.wdtFeed();
delay(100);
//========================================================================// The getNewMqtt() procedure connects to the guest network, then gets the address of the
// mqtt server from a well known (to this program) website, just in case it changed. Normally
// it wouldn't change, but because everything is running on the guest wifi network, anything
// could change at any time.
// While this section of the code works, at the time of the writing the hosting website
// dropped supporting the page, so there is nothing currently in place actually using this.
void getNewMqtt() // gets a new mqtt server address if it changes by checking a web site
char ts[128];
IPAddress ip;
if (WebName.equalsIgnoreCase("X"))
return; // Nothing to get an address from, so return
connectToWifi();
WiFi.disconnect();
return;
delay(1);
if (http.begin(client,WebName))
{ // HTTP connection to the public server and page that has the mqtt address.
// start connection and send HTTP header
int httpCode = http.GET();
if (httpCode > 0) {
// HTTP header has been sent and Server response header has been handled
// file found at server
if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY || httpCode == HTTP_CODE_FOUND)
payload.trim(); // get rid of the trailing newline
ip.fromString(payload);
if (ip[0] == 0 || ip[3] == 0) // is it a valid ip address? Starting and ending with 0 generally aren't valid.
http.end();
delay(500); // this is important. Don't remove this delay. Things go bad otherwise.
WiFi.disconnect();
return;
if (mqtt_host != ip) // check to see if the ip address changed
sprintf(ts,"R|000|Changing the mqtt address to be %d.%d.%d.%d",ip[0], ip[1], ip[2], ip[3]);
add_to_queue(ts);
xmit_the_queue(); // Actually tell the old address
mqtt_host = ip; // From this point forward the address is changed.
strcpy(eeprom_data.validate,"valid");
wifi_ssid.toCharArray(eeprom_data.ssid,wifi_ssid.length() + 1);
wifi_password.toCharArray(eeprom_data.password,wifi_password.length() + 1);
eeprom_data.mqtt = IPAddress(ip[0], ip[1], ip[2], ip[3]);
WebName.toCharArray(eeprom_data.webname,WebName.length() + 1);
EEPROM.begin(512);
EEPROM.put(0,eeprom_data);
EEPROM.commit();
EEPROM.end();
sprintf(ts,"R|000|EEPROM mqtt address is now %d.%d.%d.%d",ip[0], ip[1], ip[2], ip[3]);
add_to_queue(ts);
add_to_queue((char *)"E|[HTTP] GET... failed");
http.end();
WiFi.disconnect();
delay(250);
tcpCleanup();
//========================================================================// The add_to_queue() procedure adds a character string to the mqtt queue. As part of that
// process, it will also timestamp and format the added line. It doesn't send anything,
// it just queues it internally to the Wemos.
void add_to_queue(char* str)
char ts[128];
// Everything added to the queue has the same prefix and suffix
// The my_ssid part is simply diagnostics, except in the case of the boiler monitor.
if (strlen(str) > 90) // Just to keep the string within the required length
return;
sprintf(ts, "%-6s|%04d-%02d-%02d %02d:%02d:%02d|%s|-|", my_ssid, year(), month(), day(), hour(), minute(), second(),str);
ts[QUEUE_WIDTH - 1] = '\0';
if (queue_len < (QUEUE_MAX))
strcpy(queue+queue_pos,ts);
queue_pos += QUEUE_WIDTH;
queue_len++;
//========================================================================// The xmit_the_queue() procedure takes all of the queued entries (added by add_to_queue())
// and sends them to the mqtt server. It does this by connecting to the guest network, then
// sending the queued items in first-in-first-out order to the mqtt system. After the queue
// has been cleared, it disconnects from the mqtt server, waits, then disconnects from the
// wifi guest network.
void xmit_the_queue()
char ts[128];
uint8_t j;
uint16_t queue_position;
if (!queue_len)
return;
connectToWifi();
return;
ESP.wdtFeed();
mqttClient.connect();
j = 0;
while (!mqttClient.connected() && j < 200) // give it up to 4 seconds to connect to mqtt
delay(25);
j++;
if (mqttClient.connected() && queue_len)
ESP.wdtFeed();
queue_position = 0; // Used for getting info out of the queue FIFO, versus pulling from the end
do
queue_len--; // queue_len is the number of entries in the queue
strcpy(ts,queue + queue_position);
queue_position += QUEUE_WIDTH;
if (strlen(ts) > 0)
mqttClient.publish(MQTT_NAME, 2, true, ts);
delay(250); // We do have to wait for it to clear
} while (queue_len > 0);
queue_pos = 0;
mqttClient.disconnect();
ESP.wdtFeed();
WiFi.disconnect();
delay(250);
tcpCleanup();
//========================================================================// This simple function compares two values to see if they are different by more than maxDiff
bool checkDiff(float newValue, float prevValue, float maxDiff)
return !isnan(newValue) &&
(newValue < prevValue - maxDiff || newValue > prevValue + maxDiff);
//========================================================================// This is the main processing loop for the system.
// The loop itself is really small. Essentially it does stuff at certain
// intervals, and queues up the resulting responses.
void loop()
int i;
server.handleClient(); // used to handle configuration changes through the web interface
if (hour() != last_hour && minute() > 56) // At the end of each hour, do nothing for 3 minutes
ESP.wdtFeed();
return;
switch( modbus_state )
case 0:
if (millis() > modbus_wait)
modbus_state++; // wait state
break;
case 1:
ESP.wdtFeed();
registers[modbus_slave][i] = 0;
telegram.u8id = 0x30 + modbus_slave; // slave address
telegram.u8fct = 3; // function code (this one is registers read)
telegram.u16RegAdd = 0; // start address in slave
telegram.u16CoilsNo = 40; // number of elements (coils or registers) to read
telegram.au16reg = ®isters[modbus_slave][0]; // pointer to a memory array in the Arduino
modbusClient.query( telegram );
modbus_state++; // now looking for responses
modbus_slave++; // set up for the next slave
break;
case 2:
ESP.wdtFeed();
modbusClient.poll(); // check incoming messages
if (modbusClient.getState() == COM_IDLE) // COM_IDLE is after we've received our response
process_holding_registers(0); // this queues up the data for mqtt
modbus_state = 0;
if (modbus_slave > (MODBUS_DEVICES - 1))
modbus_wait = millis() + TIME_BETWEEN_POLLING; // reset for the next loop
modbus_slave = 0;
break;
// if we aren't looking from a response from a remote device, then it's ok to do other stuff
if (modbus_state == 0)
// every 15 seconds check the pcf9574.
if (millis() > PCF8574_wait && pcf8574Found)
PCF8574_wait = millis() + PCF8574_INTERVAL; // reset to check in another 15 seconds
read_pcf8574_pins(0); // Don't do a forced read
xmit_the_queue(); // if anything is queued up, send it off
if (millis() > PCF8591_wait && pcf8591Found)
PCF8591_wait = millis() + PCF8591_INTERVAL; // Check in another minute
read_pcf8591(0); // Don't do a forced read
xmit_the_queue();
if (millis() > blast_time)
request_wait = millis() + TIME_BETWEEN_POLLING + time_offset;
blast_time = millis() + BLAST_INTERVAL + time_offset;
// modbus_wait is not affected by this loop. That is set separately and occurs at TIME_BETWEEN_POLLING intervals regardless of the reporting intervals.
get_local_ds18b20s(1); // force a read of all the ds18b20s
if (pcf8574Found)
read_pcf8574_pins(1); // this is a forced read, so we send the pins regardless of anything changing
if (pcf8591Found)
read_pcf8591(1);
process_holding_registers(1);
char ts1[45];
uint32_t heap_free;
uint16_t heap_max;
uint8_t heap_frag;
add_to_queue(ts1);
add_to_queue(ts1);
add_to_queue(ts1);
add_to_queue(ts1);
xmit_the_queue();
if (millis() > request_wait) // Just send what has changed since the last blast
get_local_ds18b20s(0); // get the local stuff
// process the holding registers from the polled devices
process_holding_registers(0); // don't force an update
xmit_the_queue();
// Things get interesting at 4am-ish. It would be 2am, but then I'd have to deal with daylight savings at the same time
if (hour() == 4 && minute() > 20 && !time_was_set) // Get the time at 4am-ish, so we aren't too far off as time passes
{ // The time_was_set variable is used so we only get the time once a day.
if (!getTimeFromHttp()) // this gets the time
add_to_queue((char *)"E|000|Failed to get the time from HTTP");
xmit_the_queue();
delay(5000);
ESP.restart(); // reboot because something is seriously wrong
time_was_set = true; // say we got the 4am time so we don't loop around and try again immediately
if (hour() < 1 && minute() > 30 && millis() > MILLIS_MAX) // Reboot every two or three days, due to a weird connection problem with the local network
{ // Two or three days means "only boot between 12:30am and 1am", which can stretch things out a bit.
xmit_the_queue();
delay(5000);
ESP.restart();
if (hour() > 4)
time_was_set = false; // after 4am it is ok to reset this flag.
} // end of if (modbus_state == 0)
//========================================================================void process_holding_registers(uint8_t force)
char temp_message[128];
uint8_t i,j,k;
float newTemp;
// Note that modbus doesn't really handle negative values that well. Everything is a positive integer.
for (j = 0; j < MODBUS_DEVICES; j++) // for each unit that is polled we check the registers
k = 0;
if (registers[j][i] > 0)
k = 1; // all k does is indicate that there is a value other than 0 in one of the fields
if (k) // we got something from a device cause not everything is 0
for (i = 0; i < 6; i++) // there are up to six ds18b20s on each remote device, that is a fixed value on the remote
if (registers[j][i*4] > 0) // If this DS18B20 has a temperature that isn't 0, then queue it up
newTemp = float(registers[j][i * 4] / 100.0);
if (checkDiff(newTemp, float(last_registers[j][i * 4] / 100.0), 0.55) || force) // only update if something changed or we are forcing one
last_registers[j][i * 4] = registers[j][i * 4];
sprintf(temp_message, "T|%c|%03d|%06.2f|%04x%04x%04x",0x30 + j, registers[j][25],newTemp,registers[j][(i*4)+1], registers[j][(i*4)+2], registers[j][(i*4)+3]);
add_to_queue(temp_message); // send to mqtt after queuing
// now pull the humidity readings from the HTU21D sensor on each remote device
if (registers[j][28] > 0)
newTemp = float(registers[j][28] / 100.0);
if (checkDiff(newTemp, float(last_registers[j][28] / 100.0), 0.55) ||
checkDiff(float(registers[j][26] / 10.0), float(last_registers[j][26] / 10.0), 0.55) ||
checkDiff(float(registers[j][27] / 10.0), float(last_registers[j][27] / 10.0), 0.55) || force) // only update if it changed from the last time
last_registers[j][26] = registers[j][26];
last_registers[j][27] = registers[j][27];
last_registers[j][28] = registers[j][28];
sprintf(temp_message, "H|%c|%03d|%06.2f|%05.2f|%05.2f",0x30 + j, registers[j][25],newTemp,float(registers[j][26] / 10.0), float(registers[j][27] / 10.0));
add_to_queue(temp_message); // send to mqtt later
//========================================================================// All printBinary does is convert the bits in inByte to a string of 1's and 0's in ts.
// It may seem a bit backward, because if a pin is LOW, then it prints a 1, and if the pin
// is left high, then it prints a 0. Pins float HIGH, so if they are pulled to ground, then
// that means whatever switch, relay, or contact on the far end is active, thus the LOW.
void printBinary(byte inByte, char *ts)
// if a pin is grounded (pulled low), then it is active, hence the '1'. Pins left floating are low, the '0'
for (int b = 7; b >= 0; b--)
if (bitRead(inByte, b))
*ts = '0';
ts++;
*ts = '1';
ts++;
void read_pcf8574_pins(uint8_t forced)
char pcf8574_message[128];
char ts[9];
uint8_t val;
if (!pcf8574Found)
return;
Wire.requestFrom(PCF8574_I2C, 1);
val = Wire.read(); // read all pins to see if any were pulled low
if (val != lastPCF8574Value || forced) // forced reads ignore whether the data has changed or not
printBinary((byte)val, ts);
ts[8] = 0;
sprintf(pcf8574_message, "P|000|%s", ts);
add_to_queue(pcf8574_message); // send to the queue to be sent to mqtt
lastPCF8574Value = val;
// This procedure reads the ADC values from the PCF8591. Up to 4 ADCs are supported, using
// an upper limit of 5V. If the PCF8591 is found during setup, this will be read about once
// a minute by the main loop. Only if the value changes by at least 0.2 volts will anything
// be reported.
// Note that the PCF8591 only has an 8-bit result, so only about 0.02 volts of gradiation
// are possible. We don't need to go down that low.
void read_pcf8591(uint8_t forced)
char pcf8591_message[128];
float adcvalue;
if (!pcf8591Found)
return;
Wire.write(0x04); // Request a sequencial read of one pin after the latter
Wire.requestFrom(PCF8591_I2C, 5); // Read all of the ADC pins sequencially
Wire.read(); // The first byte transmitted in a read cycle contains the conversion result code of the previous read cycle.
delay(5); // Give it time to do all the ADC conversions, which mostly happen during the last read
for (uint8_t i = 0; i < 4; i++) // Loop through each of the ADCs
adcvalue=(Wire.read() * 5.0) / 256.0; // Get the ADC value
if (checkDiff(adcvalue,lastPCF8591Value[i],0.2) || forced) // forced reads ignore whether the data has changed or not
sprintf(pcf8591_message, "A|000|%06.2f|%d", adcvalue,i);
add_to_queue(pcf8591_message); // send to the queue to be sent to mqtt
lastPCF8591Value[i] = adcvalue;
delay(5); // Pause briefly between each read to give it time to convert the next value
// Read the temperatures from any DS18B20s found connected to this device. If it is there,
// then it is there, otherwise just keep going. Any DS18B20 found is identified by it's
// unique address (hardcoded within the sensor), and that information is passed along to
// the main processing program (elsewhere). Temperatures are always read and transmitted
// in Celsius, for consistency with other sensor types.
void get_local_ds18b20s(uint8_t forced)
uint8_t sensor_index;
float newTemp;
delay(1);
sensor_index = 0;
do
newTemp = ds18b20s.getTempC(sensor_address); // Get the temperature from the sensor in Celsius, as it's more standard
if (checkDiff(newTemp, temperature[sensor_index], 0.55) || forced) // Only report if it has changed or if this is a forced read
temperature[sensor_index] = newTemp;
sprintf(temp_message, "T|000|%06.2f|%02x%02x%02x%02x%02x%02x", temperature[sensor_index],
sensor_address[2],sensor_address[3],sensor_address[4],sensor_address[5],sensor_address[6],sensor_address[7]);
sensor_index++;
delay(1);
} while (oneWire.search(sensor_address) && sensor_index < DS18B20_DEVICES);
// The web_modbus() routine is used by the web interface to force a read of the modbus
// devices. That is its only usage.
void web_modbus()
uint8_t state;
uint8_t slave;
uint8_t i;
state = 1;
slave = 0;
do
switch( state )
case 0:
server.sendContent("Finished polling modbus<br>"); // print the message to the web page
return;
case 1:
delay(1);
for (i = 0; i < MODBUS_REGISTERS; i++) // Reset the registers to 0
registers[slave][i] = 0;
telegram.u8id = 0x30 + slave; // The slave address is printable in this case
telegram.u16RegAdd = 0; // starting register address in slave
telegram.u16CoilsNo = MODBUS_REGISTERS; // number of elements (coils or registers) to read
telegram.au16reg = ®isters[slave][0]; // pointer to a memory array in the Arduino
sprintf(temp_message,"Polling device %c<br>",slave + 0x30);
server.sendContent(temp_message);
modbusClient.query( telegram ); // send query to the slave (only once)
state++; // Change the status to show that we're now looking for responses
break;
case 2:
delay(1);
modbusClient.poll(); // check incoming messages from the slave
if (slave > (MODBUS_DEVICES - 1))
state = 0;
server.sendContent(F("Processing holding registers...<br>"));
web_process_holding_registers(); // this prints the holding registers to the web page
state = 1;
break;
} // end of processing the slaves through modbus
} while (1);
// The web_process_holding_registers() routine is just going to print the results of the
// registers to the web page, regardless of anything changing. It is mainly a trimmed down
// version of process_holding_registers.
void web_process_holding_registers()
uint8_t i,j,k;
float newTemp;
k = 0;
delay(1);
if (registers[j][i*4] > 0) // If this DS18B20 has a temperature that isn't 0, then print it
sprintf(temp_message, "T|%c|%03d|%06.2f|%04x%04x%04x<br>",0x30 + j, registers[j][25],newTemp,registers[j][(i*4)+1], registers[j][(i*4)+2], registers[j][(i*4)+3]);
server.sendContent(temp_message); // send to the web page
sprintf(temp_message, "H|%c|%03d|%06.2f|%05.2f|%05.2f<br>",0x30 + j, registers[j][25],newTemp,float(registers[j][26] / 10.0), float(registers[j][27] / 10.0));
server.sendContent(temp_message); // print the message to the web page
//========================================================================// handleConfig() is a procedure called by the web server. It allows for changes to the
// network, the address of the mqtt server, and the public name of the web site that also
// has the mqtt server address. Without this procedure the device will never connect to
// the local wifi network, unless everything was setup properly in eeprom.
void handleConfig()
char ts[200];
if (server.hasArg("ssid")&& server.hasArg("Password")&& server.hasArg("MQTT_IP")) //If all form fields contain data call handleSubmit()
handleSubmit();
else // Display the form
delay(1);
server.sendHeader(F("Cache-Control"), F("no-cache, no-store, must-revalidate"));
server.sendHeader(F("Pragma"), F("no-cache"));
server.sendHeader(F("Expires"), "-1");
server.setContentLength(CONTENT_LENGTH_UNKNOWN);
// here begin chunked transfer
server.send(200, "text/html");
server.sendContent(F("<!DOCTYPE HTML><html><head><meta content=\"text/html; charset=ISO-8859-1\" http-equiv=\"content-type\">" \
"<meta name = \"viewport\" content = \"width = device-width, initial-scale = 1.0, maximum-scale = 1.0, user-scalable=0\">"));
server.sendContent(F("<title>Configuration</title><style>\"body { background-color: #808080; font-family: Arial, Helvetica, Sans-Serif; Color: #000000; }\"</style></head>"));
server.sendContent(F("<body><h1>Configuration</h1><FORM action=\"/config\" method=\"post\">"));
sprintf(ts,"<P><label>SSID: </label><input maxlength=\"30\" value=\"%s\" name=\"ssid\"><br>",wifi_ssid.c_str());
server.sendContent(ts);
sprintf(ts,"<label>Password: </label><input maxlength=\"30\" value=\"%s\" name=\"Password\"><br>",wifi_password.c_str());
sprintf(ts,"<label>MQTT IP: </label><input maxlength=\"15\" value=\"%d.%d.%d.%d\" name=\"MQTT_IP\"><br> ",mqtt_host[0],mqtt_host[1],mqtt_host[2],mqtt_host[3]);
sprintf(ts,"<label>HTTP Web Name: </label><input maxlength=\"63\" value=\"%s\" name=\"WebName\"><br> ",WebName.c_str());
server.sendContent(F("<INPUT type=\"submit\" value=\"Send\"> <INPUT type=\"reset\"></P>"));
sprintf(ts,"<P><br>I think the time is %04d-%02d-%02d %02d:%02d:%02d</P></FORM></body></html>",year(), month(), day(), hour(), minute(), second());
delay(1);
server.client().stop();
//========================================================================// Report on the status of everthing through the web interface, mainly from 192.168.4.1.
// This routine is very helpfull for ensuring everthing is setup properly.
void handleStatus()
char ts[150];
uint16_t queue_length;
int16_t last_read = (millis() - read_time) / 1000;
char pcf8574_vals[9];
uint8_t val;
float adcvalue;
delay(1);
modbus_state = 4; // This is so we are exclusive while the web page is being processed
server.sendHeader(F("Expires"), F("-1"));
// here begin chunked transfer a line at a time
delay(1);
sprintf(ts,"<html><head><title>%s Status</title>",my_ssid);
server.sendContent("</head><body>");
sprintf(ts,"<P><h1>%s Status</h1><br>Version %s<br>",my_ssid, VERSION);
sprintf(ts,"WiFi SSID is %s<br>",wifi_ssid.c_str());
sprintf(ts,"WiFi password is %s<br>",wifi_password.c_str());
sprintf(ts,"MQTT host is %d.%d.%d.%d<br>",mqtt_host[0],mqtt_host[1],mqtt_host[2],mqtt_host[3]);
sprintf(ts,"Fallback name is %s<br>",WebName.c_str());
sprintf(ts,"Last reading was %d seconds ago.<br>",last_read);
sprintf(ts,"There are %d queued entries.<br>",queue_len);
sprintf(ts,"Free heap is currently %ld<br>",(long int)ESP.getFreeHeap());
sprintf(ts,"Heap fragmentation is %d<br>",ESP.getHeapFragmentation());
sprintf(ts,"MaxFreeBlockSize is %ld<br>",(long int)ESP.getMaxFreeBlockSize());
sprintf(ts,"I think the time is %04d-%02d-%02d %02d:%02d:%02d</P>", year(), month(), day(), hour(), minute(), second());
delay(1);
if (pcf8574Found)
printBinary((byte)val, pcf8574_vals); // Convert to a string
pcf8574_vals[8] = 0;
sprintf(ts,"Pins are :%s<br>",pcf8574_vals);
server.sendContent(F("No PCF8574 pins found.<br>"));
if (pcf8591Found)
Wire.requestFrom(PCF8591_I2C, 5); // Read all of the ADC pins at once
Wire.read(); // This is really just a dummy byte, technically left over from the last transmission
adcvalue=(Wire.read() * 5) / 256; // Get the value of each ADC, and adjust for a 5V reference
sprintf(ts, "Analog %d: %6.2f<br>", i,adcvalue);
delay(5); // Give some time for conversions
server.sendContent(F("No PCF8591 found.<br>"));
delay(1);
do
sprintf(ts,"%6.2f on %02x%02x%02x%02x%02x%02x<br>",ds18b20s.getTempF(sensor_address),sensor_address[2],sensor_address[3],sensor_address[4],sensor_address[5],sensor_address[6],sensor_address[7]);
delay(1);
server.sendContent(F("Reading modbus devices...<br>This could take around 20 seconds<br>"));
web_modbus();
server.sendContent(F("Finished with modbus devices.<br>"));
server.sendContent(F("All sensors have been read<br>"));
server.sendContent(F("__________________________<br>"));
server.sendContent(F("Reading the mqtt queue<br>"));
delay(1);
if (queue_len)
queue_length = queue_len; // queue_length is just the copy within this procedure, vs queue_len, which is the global value
queue_position = 0; // Used for getting info out of the queue FIFO, versus pulling from the end. This is the local copy.
do
queue_length--;
sprintf(ts,"%s<br>",queue + queue_position);
delay(1);
} while (queue_length > 0);
server.sendContent(F("Finished reading the mqtt queue<br>"));
server.sendContent(F("</body></html>"));
server.sendContent(""); // this closes out the send
modbus_state = 0; // return things to normal
//========================================================================// The handleSubmit() procedure takes whatever values were submitted by the /config page and
// updates the eeprom and global variables to the new ssid, password, mqtt server, etc.
void handleSubmit()
int i;
IPAddress ip;
String response="<!DOCTYPE HTML><html><head><meta content=\"text/html; charset=ISO-8859-1\" http-equiv=\"content-type\">" \
"<meta name = \"viewport\" content = \"width = device-width, initial-scale = 1.0, maximum-scale = 1.0, user-scalable=0\">";
response += "<p>The ssid is ";
response += server.arg("ssid");
response +="<br>";
response +="And the password is ";
response +=server.arg("Password");
response +="<br>";
response +="And the MQTT IP Address is ";
response +=server.arg("MQTT_IP");
response +="<br>";
response +="And the Web Name is ";
response +=server.arg("WebName");
response +="</P><BR>";
response +="<H2><a href=\"/\">go home</a></H2><br>";
server.send(200, "text/html", response);
// write data to EEPROM memory
i = server.arg("ssid").length() + 1; // needed to make sure the correct length is used for the values
server.arg("ssid").toCharArray(eeprom_data.ssid,i);
i = server.arg("Password").length() + 1;
server.arg("Password").toCharArray(eeprom_data.password,i);
ip.fromString(server.arg("MQTT_IP"));
i = server.arg("WebName").length() + 1;
server.arg("WebName").toCharArray(eeprom_data.webname,i);
delay(1);
EEPROM.begin(512);
delay(1);
EEPROM.commit(); // This is what actually forces the data to be written to EEPROM.
EEPROM.end();
delay(500); // Wait for the eeprom to acually be written
// It is simpler to just restart the Wemos at this time, than try to reset all values.
ESP.restart();
//========================================================================// A very simple web page is produced by handleNotFound() when an invalid web page is
// requested of this device.
void handleNotFound()
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
message +="<H2><a href=\"/\">go home</a></H2><br>";
server.send(404, "text/plain", message);
