Page 1 of 2
problems to power esp 12, blue power led turned off
PostPosted: Wed Mar 25, 2015 5:34 am
by duchere
Hi,
I'm experiencing difficulties to just power the wifi module.
I use a AMS1117 voltage regulator with two 10uF capacitors on each side. I also tried with 100uF on both sides or 100uF/1000uF The power source is a simple 9V battery and I also tried with a DC adapter. I also tried to put in series a 7805 and AMS1117.
I simply connect VCC and CH_PD to +3.3V and GND to GND. The blue led blinks for a second, and then turns off.
Normally, the blue link should remain turned on, right ?
Thanks.
Re: problems to power esp 12, blue power led turned off
PostPosted: Wed Mar 25, 2015 12:30 pm
by rkgarg20
No, Blue LED on ESP-12 won't remain on. It will turn on only when it connects to wifi and it receives/sends data.
BTW I am able to use 5 volt supply successfully with esp8266. I did not convert to 3.3 volt.
Thanks
PostPosted: Wed Mar 25, 2015 12:32 pm
by rkgarg20
Thanks
PostPosted: Wed Mar 25, 2015 12:44 pm
by hdrut
May be you are not supplying enough current to the module?
Please measure voltage at module input AND current during startup.
Horacio
