I am fairly new in ESP8266. I am currenly trying to make a home automation system using thunkable and nodemcu. I need to fetch data from a firebase node using nodemcu - which will be updated by thunkable made app. I have encountered a problem - while fetching data from firebase using nodemcu, after a certain time (around 60 s) the board gets reset with Exception(9).
my code:
long int T1, T2, T3, T4, T5;
int T1_on, T2_on, T3_on, T4_on, T5_on;
// connect to wifi.
WiFi.begin(WIFI_SSID, WIFI_PASSWORD); Serial.print("connecting");
while (WiFi.status() != WL_CONNECTED) { Serial.println(".") ;
delay(300);
Serial.println(); Serial.print("connected: "); Serial.println(WiFi.localIP());
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
//firebase tree for WBXSS00001
Firebase.setString("WBXSS00001/EMAIL", "x");
Firebase.setInt("WBXSS00001/OnStat", 0);
Firebase.setInt("WBXSS00001/PIN", 1234);
Firebase.setString("WBXSS00001/QR", "WBXSS00001A");
Firebase.setInt("WBXSS00001/T_1", 0);
Firebase.setInt("WBXSS00001/T_2", 0);
Firebase.setInt("WBXSS00001/T_3", 0);
Firebase.setInt("WBXSS00001/T_4", 0);
Firebase.setInt("WBXSS00001/T_5", 0);
//get Timer_1,2,3,4,5 input from fbase and isolate it
if (Firebase.getInt("WBXSS00001/T_1") != 0) { T1 = Firebase.getInt("WBXSS00001/T_1"); T1_on == 1; }
else if (Firebase.getInt("WBXSS00001/T_1") == 0) { T1_on == 0; }
Serial.println(millis());
}The idea is whenever WBXSS00001/T_1 changes its value, will be saved to T1.
Now after 50 to 60 seconds the board resets itself with following msg:
Exception (9):
epc1=0x4020c850 epc2=0x00000000 epc3=0x00000000 excvaddr=0x463a336b depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffc70 end: 3fffffc0 offset: 0190
3ffffe00: 00000000 00000000 3ffffec8 3ffeea28
3ffffe10: 0000000b 3ffee9f0 3fff04c8 40206354
3ffffe20: 00000000 000001bb 3fff04c8 402077f0
3ffffe30: 3ffe8890 0000003b 3fff04c8 40207d0e
3ffffe40: 0000003b 3ffee9f0 0000002e 40203974
3ffffe50: 3ffffe98 0000003b 3ffffe80 402087a4
3ffffe60: 3ffee9ec 3ffffe80 3ffe8890 3fff0244
3ffffe70: 3ffee9ec 3ffffec8 3fff04c8 402056da
3ffffe80: 3fff07ac 003b003f 00fffec8 3fff0754
3ffffe90: 0042004f 00ff0870 3fff055c 0028002f
3ffffea0: 00feec04 00000010 3fff0342 3fff0244
3ffffeb0: 3ffee9ec 3ffe880d 3fff0244 40202e96
3ffffec0: 3fffdad0 00000000 3fff0858 3fff0244
3ffffed0: 3fffff00 3fffff00 3ffe8826 40203938
3ffffee0: 3fffff08 00000000 3fff0334 3fff0244
3ffffef0: 3ffee9ec 3ffee9f0 3ffee9e8 4020441a
3fffff00: 3ffeea28 3fff0290 3fffff90 4020866e
3fffff10: 3fffff90 00000000 3fffff40 402085e0
3fffff20: 0000000b 0000027e 0000027e 3ffeeb78
3fffff30: 00000000 3ffe86bc 3ffee9e8 40204485
3fffff40: 3ffe86bc 0000000e 3fffff90 4020875b
3fffff50: 0000000e 00000001 3fffff40 40208000
3fffff60: 007a1200 0000000e 3fffff90 402087a4
3fffff70: 00000000 3fffff90 3ffe86bc 402087da
3fffff80: 00000000 3ffe86bc 3ffee9e8 40201088
3fffff90: 3fff0334 000e000f 00feeb38 4010019d
3fffffa0: 3fffdad0 00000000 3ffeeb38 40209738
3fffffb0: feefeffe feefeffe 3ffe8580 40100cb9
<<<stack<<<
load 0x4010f000, len 3456, room 16
tail 0
chksum 0x84
csum 0x84
va5432625
~ldI have decoded the stack using ESP Exception decoder :
Exception 9: LoadStoreAlignmentCause: Load or store to an unaligned address
PC: 0x4020c850: HTTPClient::connected() at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp line 471
EXCVADDR: 0x463a336b
Decoding stack results
0x40206354: HTTPClient::disconnect(bool) at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp line 434
0x402077f0: HTTPClient::end() at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp line 425
0x40207d0e: HTTPClient::begin(String, unsigned short, String, String) at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp line 379
0x40203974: std::string::_Rep::_M_destroy(std::allocator const&) at c:\users\soumyak\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits/basic_string.tcc line 452
0x402087a4: String::copy(char const*, unsigned int) at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\cores\esp8266\WString.cpp line 214
0x402056da: FirebaseHttpClientEsp8266::begin(std::string const&, std::string const&) at C:\ARDUINO_INSTALLED\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp line 51
0x40202e96: FirebaseRequest::sendRequest(std::string const&, std::string const&, char*, std::string const&, std::string const&) at C:\ARDUINO_INSTALLED\Arduino\libraries\firebase-arduino-master\src\Firebase.cpp line 73
0x40203938: std::basic_string , std::allocator >::basic_string(char const*, std::allocator const&) at c:\users\soumyak\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits/basic_string.tcc line 218
0x4020441a: FirebaseArduino::getRequest(String const&) at C:\ARDUINO_INSTALLED\Arduino\libraries\firebase-arduino-master\src\FirebaseArduino.cpp line 101
0x4020866e: String::changeBuffer(unsigned int) at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\cores\esp8266\WString.cpp line 187
0x402085e0: String::~String() at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\cores\esp8266\WString.cpp line 125
0x40204485: FirebaseArduino::getInt(String const&) at C:\ARDUINO_INSTALLED\Arduino\libraries\firebase-arduino-master\src\FirebaseArduino.cpp line 115
0x4020875b: String::reserve(unsigned int) at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\cores\esp8266\WString.cpp line 146
0x40208000: IPAddress::fromString(char const*) at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\cores\esp8266\IPAddress.cpp line 68
0x402087da: String::String(char const*) at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\cores\esp8266\WString.cpp line 36
0x40201088: loop() at C:\Users\Soumyak\Desktop\HA-01\HA-01_code_trial\HA-01_fbase_test/HA-01_fbase_test.ino line 46
0x4010019d: esp_schedule() at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\cores\esp8266\core_esp8266_main.cpp line 125
0x40209738: loop_wrapper() at C:\Users\Soumyak\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\cores\esp8266\core_esp8266_main.cpp line 197Please help me understand this error and how to overcome it. Is my approach to code is a problem, or something else...?
my board setup as tool section:
https://ibb.co/JKbGKkX
