By pangolin
#87955
Masoud Navidi wrote:
pangolin wrote:By knowing what software it is running. We don't know that or what you are trying to do, so this is impossible to answer
what do you need to know? ask me and I will provide answer if I could.
I already asked: What software are you running? post the code of the sketch you have uploaded. Also you dont just "listen for a port", you have to choose the right port for whatever functionality you are using. If your ESP is running a webserver, it will usually listen on port 80 - but only if you specifically told it to do so - if you included OTA update code, it will be listening on port 8266. It could be listening on many...or none. It is 100% dependent on what you are trying to make it do.
I suspect just by the nature of your question, if you have not written or uploaded code to perform a well-defined and specific task then it is probably not listening at all
