I want send JSON String (JavaScript) form WebPage to ESP8266 WebServer (Micropython). When I recived POST Request, see only part of message:
Connected by ('192.168.0.2', 57002)
b'POST /jsonData HTTP/1.1\r\nHost: 192.168.0.1\r\nConnection: keep-alive\r\nContent-Length: 143\r\nUser-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.102 Safari/537.36\r\nContent-Type: application/json\r\nAccept: */*\r\nOrigin: http://192.168.0.1\r\nReferer: http://192.168.0.1/\r\nAccept-Encoding: gzip, deflate\r\nAccept-Language: pl-PL,pl;q=0.9,en-US;q=0.8,en;q=0.7\r\n\r\n{"LED_1__VERY_LONG_VARIABLE_NAME__VERY_LONG_VARIABLE_NAME__":true,"LED_2_VERY_LONG_VARIABLE_NAME__VERY_LONG_VARIABLE_NAME__":tr'
but I expected like this:
b'POST /jsonData HTTP/1.1\r\nHost: 192.168.0.1\r\nConnection: keep-alive\r\nContent-Length: 143\r\nUser-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.102 Safari/537.36\r\nContent-Type: application/json\r\nAccept: */*\r\nOrigin: http://192.168.0.1\r\nReferer: http://192.168.0.1/\r\nAccept-Encoding: gzip, deflate\r\nAccept-Language: pl-PL,pl;q=0.9,en-US;q=0.8,en;q=0.7\r\n\r\n{"LED_1__VERY_LONG_VARIABLE_NAME__VERY_LONG_VARIABLE_NAME__":true,"LED_2_VERY_LONG_VARIABLE_NAME__VERY_LONG_VARIABLE_NAME__":true,"LED_3":false}'
and here is a code:
while True:
try:
self.conn, addr = self.s.accept()
except Exception as exc:
print("Socket Accept Error ", exc.args[0])
reset()
pass
print('Connected by', addr)
try:
self.request = str(self.conn.recv(1024)) # <-- Read Buffer
print(self.request) # <-- Print POST Request msg
print("recv -------------", exc.args[0])
reset()
pass
self.connection(html)So, I have a problem with read all buffer using socket.recv(bufsize) function. The Data are truncated.
Read all socket buffer at once is not possible, so i decided read chunks - 8 Bytes each. Everything is OK when the last chunk have a other size (less than 8 bytes).
Sometimes the last chunk of data have a exactly the same length which previous chunks (8 bytes) and never break loop. So, how i can recognize last chunk and break infinite while loop?
Code:
while True:
try:
reset()
pass
try:
while True:
self.request = self.conn.recv(8) # <-- Read Chunk
print(str(self.request))
if len(self.request) < 8: # <-- Check length
print("End")
break
self.request = None
reset()
pass
