By BLCKPSTV
#89064 Hi,
I'm using this working library to extract H2 & Alcohol in PPM from sensors.
I only need the PPM for my project as I want to send this as an osc message.
But the code of the library is made up so I can only use the whole data table instead of the ppm.
This is the code:
MQUnifiedsensor Library - reading an MQ8
Demonstrates the use a MQ8 sensor.
Library originally added 01 may 2019
by Miguel A Califa, Yersson Carrillo, Ghiordy Contreras, Mario Rodriguez
Added example
modified 23 May 2019
by Miguel Califa
Updated library usage
modified 26 March 2020
by Miguel Califa
Wiring:
https://github.com/miguel5612/MQSensors ... rduino.PNG
Please take care, arduino A0 pin represent the analog input configured on #define pin
This example code is in the public domain.
//Include the library
#include <MQUnifiedsensor.h>
//Definitions
#define placa "Arduino UNO"
#define Voltage_Resolution 5
#define pin A0 //Analog input 0 of your arduino
#define type "MQ-8" //MQ8
#define ADC_Bit_Resolution 10 // For arduino UNO/MEGA/NANO
#define RatioMQ8CleanAir 70 //RS / R0 = 70 ppm
//#define calibration_button 13 //Pin to calibrate your sensor
//Declare Sensor
MQUnifiedsensor MQ8(placa, Voltage_Resolution, ADC_Bit_Resolution, pin, type);
//Init the serial port communication - to debug the library
Serial.begin(9600); //Init serial port
//Set math model to calculate the PPM concentration and the value of constants
MQ8.setRegressionMethod(1); //_PPM = a*ratio^b
MQ8.setA(976.97); MQ8.setB(-0.688); // Configurate the ecuation values to get H2 concentration
Exponential regression:
GAS | a | b
H2 | 976.97 | -0.688
LPG | 10000000 | -3.123
CH4 | 80000000000000 | -6.666
CO | 2000000000000000000 | -8.074
Alcohol | 76101 | -1.86
/***************************** MQ Init ********************************************/
//Remarks: Configure the pin of arduino as input.
MQ8.init();
//If the RL value is different from 10K please assign your RL value with the following method:
MQ8.setRL(10);
/***************************** MQ CAlibration ********************************************/
// Explanation:
// In this routine the sensor will measure the resistance of the sensor supposing before was pre-heated
// and now is on clean air (Calibration conditions), and it will setup R0 value.
// We recomend execute this routine only on setup or on the laboratory and save on the eeprom of your arduino
// This routine not need to execute to every restart, you can load your R0 if you know the value
// Acknowledgements: https://jayconsystems.com/blog/understa ... gas-sensor
Serial.print("Calibrating please wait.");
float calcR0 = 0;
for(int i = 1; i<=10; i ++)
MQ8.update(); // Update data, the arduino will be read the voltage on the analog pin
calcR0 += MQ8.calibrate(RatioMQ8CleanAir);
Serial.print(".");
MQ8.setR0(calcR0/10);
Serial.println(" done!.");
if(isinf(calcR0)) {Serial.println("Warning: Conection issue founded, R0 is infite (Open circuit detected) please check your wiring and supply"); while(1);}
if(calcR0 == 0){Serial.println("Warning: Conection issue founded, R0 is zero (Analog pin with short circuit to ground) please check your wiring and supply"); while(1);}
MQ8.serialDebug(true);
MQ8.readSensor(); // Sensor will read PPM concentration using the model and a and b values setted before or in the setup
MQ8.serialDebug(); // Will print the table on the serial port !!!!!!!!!!!!!!!!! this is the table !!!!!
delay(500); //Sampling frequency
This is the library:
From 63 till 103 is the part that prints the table. I want to get the _PPM alone in my loop so I can add it to my osc message.
https://raw.githubusercontent.com/miguel5612/MQSensorsLib/master/src/MQUnifiedsensor.cpp
I tried several things but nothing gets the _PPM message in my SerialPrint and or OSCmessage
