I'm not sure if is a requirement to flash the esp01 in order to use it.
And also what does "flashing" means in this context?
Do I need to flash esp01 in order to upload code ?
Thanks
Explore... Chat... Share...
schufti wrote:is it really that complicated???
https://www.youtube.com/results?search_ ... duino+ide+
