By remkohuitema
#89760 I've changd in a script the hardware serial to softwareserial because a change in my hardware. I got a lot of errors so to get ride of all the errors I try to start with a fresh arduino surrounding. So I update to the arduino 1.8.12 IDE and followed this instruction (for mac):
https://arduino-esp8266.readthedocs.io/en/latest/installing.html#using-git-version
I understand the library ' softserial' is included in the esp8266 build so no need to add a softseriallibrary manually (so I thought).
Now when I/m trying to compile my code I do get an error:
Code: Select allSoftwareSerial.h: No such file or directory
This is my script:
Code: Select all/*
* This sketch reads a command through a http connection
* depending on the text received it will send open, stop or close
* commands to the Esp8266. the ESP8266 is connected to the Axa Remote 2.0 electric window opener
#include <SoftwareSerial.h> // For Swapping TX/RX
#define rxPin 1
#define txPin 3
#define MAX_MSG_LEN (128) // maximum MQTT recieved message length
const byte numChars = 128; // maximum SERIAL recieved message length
char receivedChars[numChars]; // an array to store the received message
const byte numCode = 4; // maximum SERIAL recieved message length
char receivedCode[numCode]; // an array to store the received code
boolean newData = false;
SoftwareSerial SoftSerial(rxPin, txPin);  // Software serial
const char* ssid = "xxx";
const char* password = "xxx";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  SoftSerial.begin(19200,SWSERIAL_8N1);
delay(10);
// Connect to WiFi network
WiFi.begin(ssid, password);
// Start the server
server.begin();
if (!client) {
return;
while(!client.available()){
delay(1);
client.flush();
// Match the request
int val;
if (req.indexOf("/open") != -1)
open_axa();
if (req.indexOf("/close") != -1)
close_axa();
else if (req.indexOf("/stop") != -1)
stop_axa();
else {
SoftSerial.println("invalid request");
client.stop();
return;
void open_axa() {
SoftSerial.print("O");
delay(20);
SoftSerial.print("P");
delay(20);
SoftSerial.print("E");
delay(20);
SoftSerial.print("N");
delay(20);
SoftSerial.println("\r");
delay(200);
delay(20);
delay(20);
delay(20);
delay(20);
delay(200);
delay(20);
delay(20);
delay(20);
delay(20);
delay(2000);
void close_axa() {
SoftSerial.print("C");
delay(20);
SoftSerial.print("L");
delay(20);
delay(20);
SoftSerial.print("S");
delay(20);
delay(20);
delay(2000);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(2000);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(2000);
void stop_axa() {
delay(20);
SoftSerial.print("T");
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
Do I misunderstand the fact the softserial library is included in the esp8266 build? Do I have to do something else to implant this library?
