Greetings fellows of the forum, I need your help I am starting with module esp8266-01s the theme is that I perform the connection as indicated, With a USB-TTL converter with PL2303 chip, the point is that initially when connecting the GPIO0 to Low I did not root any communication with e-app or the Arduino IDE and the Putty program, then connect the GPIO2 pin to Low (GND) and if it communicates to both the Arduino Ide and putty but I tested all the connection speeds only reads garbage, I thought it could be the power supply of the 3.3 VDC converter but after connecting it to an external source and measuring it gives me 3.35 VDC and its own amperage and still someone could help me???
@electronic2021 you say you are getting garbage. Have you tried the 74880 baud rate? Why, see here:-
Why does ESP8266 show 'Garbage' characters?
