By mnewman401
#90953 There appears to be a bug in core_esp8266_si2c.cpp. I am using library version 2.7.4 and have seen the bug in previous versions too. I am unsure where to post this to get it into the queue of fixes.
When Twi::readFrom() is passed a 0 length the code does not test for this condition and reads many bytes instead of reading none.
What follows is patched code that solves this problem.
unsigned char Twi::readFrom(unsigned char address, unsigned char* buf, unsigned int len, unsigned char sendStop)
unsigned int i;
if (!write_start())
return 4; //line busy
if (!write_byte(((address << 1) | 1) & 0xFF))
if (sendStop)
write_stop();
return 2;//received NACK on transmit of address
// MJN: ??? Handle case of 0 bytes requested by
// checking for 0 and reading nothing.
if (len > 0) {
// End of MJN fragment
for (i = 0; i < (len - 1); i++)
buf[i] = read_byte(false);
buf[len - 1] = read_byte(true);
// MJN: Close conditional
// MJN: end of MJN fragment
// More code follows that needs no changes.
