import serial
sp="/dev/ttyUSB0"
port = serial.Serial(sp)
while True:
port.write("AT+RST")
rcv = port.read(10)
print rcvdont work, please help!
Explore... Chat... Share...
import serial
sp="/dev/ttyUSB0"
while True:
rcv = port.read(10)
print rcvport = serial.Serial(sp, 115200)
port = serial.Serial(sp, 57600)
