I managed to connect and readout a pms7003 connected to an esp8266 with arduino code. The sensor does something weird however. Every 99 seconds it steeply increases dust levels as if a constant was added to the readings for 10 seconds and then returns again to its normal values. I tried two different sensors, active and passive mode, changed out power source and library uses (pms.h and pmserial.h). Same thing. Does anyone have an idea about what is wrong?
Thanks and best regards!
