i'd like control mcp4561 digital potentiometer with esp2561 but i have no code for the esp8266 .
i have an arduino code , could it be modified to be used with the esp8266 ?
Explore... Chat... Share...
davydnorris wrote:There is an Arduino ESP8266 port
Just go into the Arduino Boards Manager and add the appropriate ESP module then you will most likely be able to use the Arduino code directly
momuhammad wrote:So what about mqtt and wifi credentials ?
