Here is the wiring diagram, I’ve used an arduino uno because there is only that available in Tinkercad.
https://imgur.com/a/ykn6Uqo
I made a list of considerations/things I’ve tried to do:
-I’m using a 5V 3A power supply
-There is a one meter shielded cable from the power supply to the board
-There is a 230V lightbulb near the electronics but even if it’s not powered the problem remains
-With or without the 10µF capacitor it doesn’t change anything
-Before adding the diode I was having the same problem even if the board was powered via usb
-I’ve tried to re-solder the ESP8266 connections to the pcb
-I’ve uploaded the sketch to another identical board and to an AZDelivery NodeMCU board, in both cases they connected in less then 10 seconds
-I’ve tried to change the power supply and I even tried to power everything via usb by splicing a cable but the problem remains
-I’ve tried to unsolder the cables that power the board and solder them to a usb micro cable to power the board via usb but nothing changed
-I remove the one meter cable and I powered everything near the circuit, it connect in 4 second with every power supply that I have
-I’ve tried to reattach the cable but with better terminals an it still worked
I was convinced I found the problem so I removed the terminals and soldered the wires together to be safe but I’m back where I started, now it takes 10 minutes to connect even via usb.
I don't know what to do anymore, I hope someone can help me
