If this topic has been covered and resolved before, then I apologize.
Since I have read many threads and tried to find a solution but haven't found it yet, so I have to create this thread.
In Windows and iOS 14, WPA2 TKIP mode is warned of risks. So I want to install WPA2 AES or WPA3 mode ut i didn't find the solution.
And, I want to change Radio Type from 802.11g to 802.11n.
(I have used the code below but still not working. )
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <ESP8266HTTPUpdateServer.h>
#include <EEPROM.h>
const char* ssid = "HIEUVAITHANH";
const char* password = "123456789";
const char* host = "WifiReperater2";
const char* updatePath = "/update";
const char* updateUsername = "admin";
const char* updatePassword = "admin";
// Your ESP Wifi
const char* ssid_soft_ap = "SMARTSWITCH 2021 3CH";
const char* password_soft_ap = "switch2021"; // My preference is same as my home ssid password.
int Wifi_SoftAP_Channel = 11;
// ESP 8266 Local Network Configuration
IPAddress local_IP(192,168,4,1);
IPAddress gateway(192,168,4,1);
IPAddress subnet(255,255,255,0);
ESP8266WebServer webServer(80);
ESP8266HTTPUpdateServer httpUpdater;
const char MainPage[] PROGMEM = R"=====(
<title>SMARTSWITCH</title> <style> body{ text-align: center; } </style>
<div>
<button onclick="window.location.href='/update'">UPLOAD FIRMWARE</button><br><br>
</div>
<script>
</script>
void setup(void){
Serial.println("Booting programs...");
WiFi.setPhyMode(WIFI_PHY_MODE_11N);
WiFi.printDiag(Serial);
EEPROM.begin(512);
// write a 0 to all 512 bytes of the EEPROM
for (int i = 0; i < 512; i++) {
EEPROM.write(i, 0);
// turn the LED on when we're done
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
EEPROM.end();
WiFi.mode(WIFI_AP_STA);
WiFi.begin(ssid, password);
while(WiFi.waitForConnectResult() != WL_CONNECTED){
Serial.println("WiFi failed, retrying.");
Serial.println(" kết nối internet voi");
Serial.println(ssid);
Serial.print("PASS ");
Serial.println(password);
Serial.print("IP address: ");
WiFi.softAPConfig(local_IP, gateway, subnet);
WiFi.softAP(ssid_soft_ap, password_soft_ap, Wifi_SoftAP_Channel);
MDNS.begin(host);
MDNS.addService("http", "tcp", 80);
httpUpdater.setup(&webServer, updatePath, updateUsername, updatePassword);
webServer.on("/",[]{
String s = MainPage;
webServer.send(200,"text/html",s);
webServer.begin();
Serial.println("Web Server is started!");
//=========Chương trình Chính=====//
pinMode(D4,OUTPUT);
//============End=================//
void loop(void){
MDNS.update();
webServer.handleClient();
//====Chương trình Chính==========//
digitalWrite(D4,!digitalRead(D4));
//=========End====================//
Therefore, I hope you can help me fix the above 2 problems.
I sincerely thank you.
