ets Jan 8 2013,rst cause:4, boot mode:(1,7)
Platform
Hardware: [ESP8266]
Development Env: [Arduino IDE]
Operating System: [Windows 10]
wdt reset
#include <Adafruit_ADS1X15.h>
#include <Wire.h>
// Adafruit_ADS1115 ads; /* Use this for the 16-bit version */
Adafruit_ADS1015 ads; /* Use thi for the 12-bit version */
void setup(void)
delay(100);
Wire.begin(5, 4);// GPIO5 - SCL, GPIO4 SDA
// The ADC input range (or gain) can be changed via the following
// functions, but be careful never to exceed VDD +0.3V max, or to
// exceed the upper and lower limits if you adjust the input range!
// Setting these values incorrectly may destroy your ADC!
// ADS1015 ADS1115
// ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV 0.1875mV (default) // activate this if you are using a 5V sensor, this one should be used with Arduino boards
ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV // As the sensor is powered up using 3.3V, this one should be used with 3.3v controller boards
// ads.setGain(GAIN_TWO); // 2x gain +/- 2.048V 1 bit = 1mV 0.0625mV
// ads.setGain(GAIN_FOUR); // 4x gain +/- 1.024V 1 bit = 0.5mV 0.03125mV
// ads.setGain(GAIN_EIGHT); // 8x gain +/- 0.512V 1 bit = 0.25mV 0.015625mV
// ads.setGain(GAIN_SIXTEEN); // 16x gain +/- 0.256V 1 bit = 0.125mV 0.0078125mV
// if (!ads.begin()) {
// Serial.println("Failed to initialize ADS.");
// while (1);
// yield();
void loop(void)
int16_t adc0, adc1, adc2, adc3;
ESP.wdtFeed();
//ESP.wdtDisable();
adc0 = ads.readADC_SingleEnded(0);
delay(1000);
adc1 = ads.readADC_SingleEnded(1);
delay(10);
// adc2 = ads.readADC_SingleEnded(2);
// adc3 = ads.readADC_SingleEnded(3);
Serial.print("AIN0: "); Serial.println(adc0);
Serial.print("AIN1: "); Serial.println(adc1);
// Serial.print("AIN2: "); Serial.println(adc2);
// Serial.print("AIN3: "); Serial.println(adc3);
