Page 1 of 2
ESP-07 doesn't react to AT commands, programming works OK
PostPosted: Fri Sep 10, 2021 3:12 pm
by esperanzo
I have an ESP-07 which does not react to AT commands as opposed to an ESP-12F which works properly with AT commands.
I did upload a blink sketch to the ESP-07 using the arduino IDE, and it worked fine.
The I also successfully updated to the latest firmware, but AT commands still do not work.
There is just no response at all.
Attached is a screenshot of the firmware update.
Is there a problem with the latest firmware or am I missing something else here?
Re: ESP-07 doesn't react to AT commands, programming works O
PostPosted: Sat Sep 11, 2021 4:05 am
by JurajA
the sketch replaced the AT firmware.
esptool.py write_flash --flash_size 1MB 0x0 boot_v1.7.bin 0x01000 at/512+512/user1.1024.new.2.bin 0xfb000 blank.bin 0xfc000 esp_init_data_default_v08.bin 0xfe000 blank.bin 0x7e000 blank.bin
PostPosted: Sat Sep 11, 2021 1:46 pm
by esperanzo
Sorry for not being precise enough.
AT commands did not work in the first place, so I uploaded a sketch to see if this worked.
I am aware that the sketch replaced the AT firmware, and I did the firmware update shown in the screenshot after I had tested with the sketch.
The newly installed firmware re-installs the AT commands, but as I wrote it still did not work.
PostPosted: Sun Sep 12, 2021 2:47 am
by esperanzo
Flashing with esptool.py write_flash --flash_size 1MB 0x0 boot_v1.7.bin 0x01000 at/512+512/user1.1024.new.2.bin 0xfb000 blank.bin 0xfc000 esp_init_data_default_v08.bin 0xfe000 blank.bin 0x7e000 blank.bin
worked, but AT commands still show no response at all.
I have a second ESP-07 which still has the factory firmware which gives me the following output @74880 baud at boot.
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
My newly flashed ESP-07 shows boot version 1.7 while the other values are the same.
The AT problem is the same as on both of the ESP-07.
I did also flash my ESP-12 with the latest firmware 1.7 and this one has no problems with AT commands.
My suspicion is, that the ESP-07 either have a flash ROM problem beyond 0x1000, which is the jump start address for AT commands, or the clock frequency for AT commands is not within the correct limits.
