Page 1 of 2
NTP udp packets not received on A.T.&T network -Resolved
PostPosted: Sun Jan 16, 2022 11:55 am
by Sirquil
Have a ESP8266, sump pit monitor that uses NTP; it works perfectly with our Xfinity, network router. ESP8266 connects to the AT&T router; does not receive UDP packets. Firewall has been configured on the NVG588; still, does not work. UDP port is defined as 1337.
A.T.&T router is a Arris NVG588.
Has anyone else experience this issue? Any work around to fix this issue?
William
Re: NTP udp packets not received on A.T.&T network
PostPosted: Sat Jan 29, 2022 7:36 am
by rpiloverbd
Hello, Have you got any solution to this problem? Have you considered posting this question to the A.T & T network users community?
PostPosted: Wed Feb 09, 2022 11:13 pm
by lindadieggoo
Sirquil wrote:Have a ESP8266, sump pit monitor that uses NTP; it works perfectly with our Xfinity, network router. ESP8266 connects to the AT&T router; does not receive UDP packets. Firewall has been configured on the NVG588; still, does not work. UDP port is defined as 1337.
A.T.&T router is a Arris NVG588. drift hunters
William
Hi, I'm looking for a solution to this problem!
Re: NTP udp packets not received on A.T.&T network -resolved
PostPosted: Sun Feb 13, 2022 8:19 am
by Sirquil
Issue was a misconfigured network; I used 192.168.1.1 for gateway and dns. Even with the 192.168.1.1 Gateway and dns project was connecting to the AT&T network; just not "talking" to the gateway and dns
AT&T network; in this case, used gateway and dns of 192.158.1.254.
Had I checked Windows PC with ipconfig; would have caught this much sooner, instead of going from "memory."
