ULN2003A is a seven-channel Darlington array used to interface microcontrollers to high voltage, high current devices such as solenoids, lamps, relays, etc. It has the capacity to drive 500mA into a single channel, up to 250mA per channel if four of the seven channels are active and 125 mA per channel if all the seven channels are active. Its output has clamp diodes for transient suppression to protect the low-power microcontroller circuits.
The ULN2003 is the replacement for the ULN2803 when using the Prop-1 Trainer Board or when using P7 (Prop-1) or P15 (Prop-2 and Prop-SX) for serial communications with devices like the AP-8, DC-16, FC-4, and RC-4.
ULN2803 is an eight-channel Darlington array used to interface microcontrollers to high voltage, high current devices such as solenoids, lamps, relays, etc. It has the capacity to drive 500mA into a single channel, up to 250mA per channel if four of the eight channels are active and 125 mA per channel if all the eight channels are active. Its output has clamp diodes for transient suppression to protect the low-power microcontroller circuits. ULN2803 is commonly used for controlling large seven-segment displays.
