Get a JSON response from ESP8266 using fetch
PostPosted: Tue Mar 22, 2022 11:15 pm
by SuomyNonaPatri
Hi
I've created a ESP8266 web server that should send a JSON object when it's requested by the client. The code of this server looks like this:
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
WiFi.disconnect();
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
Serial.print("Successfully connected.");
Serial.println("\nGot IP: ");
Serial.print(WiFi.localIP());
if(MDNS.begin("esp8266")) {
Serial.println("MDNS responder started");
server.on("/data", []() {
server.send(200, "application/json", "{\"key\": \"value\"}");
server.begin();
server.handleClient();
MDNS.update();
Then I am trying to request the data from my JS code using fetch function. But it throws this error:
Uncaught (in promise) SyntaxError: Unexpected end of input
at index.js:8
When I simply connect to the server's data from my browser it is correctly displayed the JSON object on the page. This is my code to do request:
fetch('http://192.168.1.135/data', {
method: 'GET',
mode: 'no-cors',
headers: {
'Content-Type': 'application/json',
.then(response => response.json())
.then(data => console.log(data));
Re: Get a JSON response from ESP8266 using fetch
PostPosted: Tue Mar 29, 2022 5:23 am
by rpiloverbd
Is the code working? Giving the desired result?
PostPosted: Wed Mar 30, 2022 9:45 am
by quackmore
the browser is working but fetch is not, I might be wrong but...
specifying "mode: 'no-cors'" as a fetch option may be tricky
you are telling fetch DON'T read data across origins, resulting in an empty response
then response.json() will fail on the empty response (line 8)
to verify if that's the case just log the response, I mean use console.log(response) instead of response.json()
to fix the issue, enable cors and add the following header to the ESP8266 response
Access-Control-Allow-Origin: *
PostPosted: Sat Apr 02, 2022 6:35 am
by Inq720
Is your primary-goal to study and build a web server that works with with json?
Or are you trying to get a server up so you can do some other project needing a GUI browser client?
