Noise tests from an ESP8266-Pro in a sound project
PostPosted: Wed Aug 31, 2022 8:13 am
by Stewart
In this test I'm using GP IO04 for output of tones coupled through a 0.1uf capacitor to a small audio amplifier.
As it sits idle, a continuous cycle of ticks can be heard. A ferrite bead on the audio line reduced the amplitude, but it is still present.
Is this inherent to unshielded microcontrollers? Should I be using a shielded ESP32 maybe instead of the ESP8266-Pro?
There is no wifi in use in this test. Isn't the RF off until envoked?
Re: Noise tests from an ESP8266-Pro in a sound project
PostPosted: Thu Sep 01, 2022 6:40 am
by rooppoorali
You can switch to ESP32. But I am not sure that will solve your mentioned problem.
