By Sirquil
#96047 Good Mornnig,
Created a sketch that creates variables: "effects," "intensity," and "color pallete" for use with WLED. More details about the WLED can be found at: WLED Project
Sketch runs on ESP32 or ESP8266.
OpenAI's, ChatGPT assisted on the project.
Results of MPU6050 Accelerometer and Gyro Breakout project
Project results
Github repository of MPU6050_WLED project
Short video of WLED running
Shows WLED Strip of RGB leds lighting effects, intensity, and color palette.
Plan is to use "paddle/wand" to create changing RGB lighting effects, intensity, and color palette of WLED Controller output. Should work with any WLED Controller as only uses HTTP api. "Paddle/wand" has been named "Chromawand."
Regards,
William
(6.67 KiB) Downloaded 38 times
By Sirquil
#96173 MPU6050_WLED
Latest version no longer uses touch features; instead, it uses three switches for better user interface. Features are nearly the same. Find the latest version in the folder: MPU6050_WLED_withThree_Switches. Note: must use the new variables.h file; as variable names have changed. First time use; edit variable values to match your network nd configuration. Latest version.
Developed by William Lucid with assist from OpenAI's ChatGPT. Only partially finished; has not been added directly to running WLED, project is a work-in-progress. Will need a usermod to be added and compiled for WLED. Sketch was developed to generate varialbles to send WLED Controller using MPU6050. Generating Effects, Intensity, and
color palette variables of WLED Project. WLED Controller tested and runs on ESP32.
WLED "List of Effects and Palettes
Plan is to use a wand/paddle with the MPU6050 attached; user could "wave" the wand/paddle effecting changes RGB leds, WLED "effects," "intensity," and "color Palette."
Using MPU6050_WLED. Project:
1. Requires WLED Controller, ESP32, MPU6050
2. Read "Operation of Switches.pdf" for switch operation.
RGB Addressable Strip Controller used with MPU6050_WLED project
View Tom Parish's ORB Art Project using WLED Controller
View ORB using MPU6050_WLED Sketch
By Sirquil
#96196
Sir, have you used the WLED ESP32 Music Addressable LED Strip Controller?
Yes, project development was done using this WlED controller; costing just under $25 it is solid, well worth the cost. I have not used the microphone input.
William
