By beic
#96206 Hi there,
I'm trying to count Files on the SD Card, but for some reason the "getFileCount" function is always returning 0 value.
The weird thing is that the Config.txt file is loading without any issue.
Note: There is no Directory on the SD Card.
Any help would be appreciated.
Code: Select allvoid SDcardInit(int sPin)
  if (SD.begin(sPin)) {
    dbgCustomMsg(F("SD Card Init ... OK"));
    myDelay(200);
    sd_File_Count = getFileCount(SD);
    myDelay(200);
    ConfigLoad(); // The Config.txt is loading without any issue
  } else {
    dbgCustomMsg(F("SD Card Init ... ERR"));
    while (1) myDelay(100);
    return;
int getFileCount(SDClass& sd)
  char rootPath[] = "/";
  if (!sd.exists(rootPath)) {
    Serial.println("Root directory not found!");
    return 0;
  File root = sd.open(rootPath);
  if (!root) {
    Serial.println("Failed to open root directory!");
    return 0;
  int fileCount = 0;
  while (true) {
    File entry = root.openNextFile();
    if (!entry) {
      break;
    fileCount++;
    entry.close();
  root.close();
  return fileCount;
