Just wondered if anyone can point me in the right direction, I don't think I'm far off but some advice from a seasoned developer would be helpful, So my project I finally managed to Ethernet WebSocket working with my ESP8266 project, and this is the final hurdle. I have a page to send firmware updates from the browser, I alread have webserver implemented and because im using Ethernet I cannot use the HTTPupdater library, so I decided to use the Updater.h library native to the ESPcore.
So I get my .bin file sending from the browser to the ESP, of course this just reads and reads until the cpu does a WDT reset.
I have the function for the updater setup and this must get the file in 128byte chucks until finished then perform an ESP reset.
So in my serial monitor thats reading the String data recived I get the following when I send firmware file
Content-Disposition: form-data; name="firmware"; filename="MQTT_POESEN_V3_TS.ino.d1_mini.bin"
Content-Type: application/octet-stream
�? �? K@ �$@ ������¬���?� ����� @
I have tried to modify some code that catches the firmware file, but this is based this code I found as below.
// If file is reachable, start downloading
if(resp > 0){
// get length of document (is -1 when Server sends no Content-Length header)
totalLength = client.getSize();
// transfer to local variable
int len = totalLength;
// this is required to start firmware update process
Update.begin(UPDATE_SIZE_UNKNOWN);
Serial.printf("FW Size: %u\n",totalLength);
// create buffer for read
uint8_t buff[128] = { 0 };
// get tcp stream
WiFiClient * stream = client.getStreamPtr();
// read all data from server
Serial.println("Updating firmware...");
while(client.connected() && (len > 0 || len == -1)) {
// get available data size
size_t size = stream->available();
if(size) {
// read up to 128 byte
int c = stream->readBytes(buff, ((size > sizeof(buff)) ? sizeof(buff) : size));
// pass to function
updateFirmware(buff, c);
if(len > 0) {
len -= c;
delay(1);
Ethernet client does not have client get stream, and I am trying to work out how to get the file and its length so as I can parse data to the updater function, this is what I have so far but I realize this is wrong any pointers please, at this point my ethClient in the ESP is already running!
if (strstr(req, "firmware"))
{ //Get Firmware File Stream
int firmdat = ethClient.read(); //var to catch the bin data stream, not sure if this has to be an array
// Get file, just to check if each reachable
//int resp = firmdat;//client.GET();
Serial.print("Response: ");
Serial.println(firmdat);
//== 200
if(firmdat > 0 ){
totalLength = ethClient.getSize();
Update.begin();//UPDATE_SIZE_UNKNOWN
// get tcp stream
ethClient * stream = ethClient.getStreamPtr();
while(ethClient.connected() && (len > 0 || len == -1)) {
if(size) {
// pass to function
if(len > 0) {
len -= c;
delay(1);
}else{
Serial.println("Cannot download firmware file.Something is very wrong you messed up!!");
This code is in my web command loop and strstr catches the data as received.
and this is the updater function itself.
// Function to update firmware incrementally
// Buffer is declared to be 128 so chunks of 128 bytes
// from firmware is written to device until server closes
void updateFirmware(uint8_t *data, size_t len){
Update.write(data, len);
currentLength += len;
// Print dots while waiting for update to finish
Serial.print('.');
// if current length of written firmware is not equal to total firmware size, repeat
if(currentLength != totalLength) return;
Update.end(true);
Serial.printf("\nUpdate Success, Total Size: %u\nRebooting...\n", currentLength);
// Restart ESP to see changes
ESP.restart();
Many Thanks
Jono
