Need to improve battery life of my ESP8266 Temp Hum sensor.
Hi,
I have designed a Temp-Hum sensor for my homeassistant. I am using ESPHOME I have got issues with the battery life using a 18650 2200 mah Li-on battery. It last about a month and then need to recharge it. Any ideas to improve the life of the battery? Is there any improvement to be done or is this what I should be expecting running ESP on a battery?
ESPhome conf:
wifi:
power_save_mode: none
update_interval: 1s
deep_sleep:
run_duration: 30s
sleep_duration: 10min
I'm using
Diagram:
Any help is appreciated.
ESPhome conf:
wifi:
update_interval: 1s
deep_sleep:
run_duration: 30s
I'm using
- TP4056 Type-C 1S 3.7V LiPo charging board bms integrated.
- XC6203E332PR LDO regulator Output Current: 400 mA, Quiescent Current: 8 uA
Diagram:
