Can't send \r\n after AT+CIPSEND using serial
PostPosted: Thu Apr 16, 2015 5:24 pm
by masual
I'm trying to generate some HTTP headers with an Arduino to send before the data (a json object) in a TCP package.
Code: Select allString header = "HTTP/1.0 200 OK\r\n\r\n";
Serial.println(String(header.length()));
 if(Serial.find(">"))
    Serial.println(header);
This is the code I'm using, but I can't get the \r\n characters to be sent. I'm using wireshark to sniff the packets, and only one \n (0x0A) is been sent. I also used sscom to send the commands and obtained the same result. Any ideas?
Re: Can't send \r\n after AT+CIPSEND using serial
PostPosted: Wed Nov 18, 2015 5:09 pm
by Sebastian Heyn
Hi did you find a way to solve this issue? I came to the same problem
