I just uploaded the STEP model for the ESP-03 to 3Dcontentcentral. I have also attached the file on this message. The offset of the PCB is 1.1mm.
Kind regards,
Mark
(500.02 KiB) Downloaded 261 times
Explore... Chat... Share...
