Serial.begin(115200);Serial.print("Some text");Explore... Chat... Share...
Serial.begin(115200);Serial.print("Some text");ArnieO wrote:That works for me, so you need to look for some kind of error in your setup.
Leandro Silva wrote:ArnieO wrote:That works for me, so you need to look for some kind of error in your setup.
When I compile my code, does the IDE send the firmware to the ESP? I remember that a few weeks ago I was using NodeMCU and I was thinking if maybe the NodeMCU firmware is in conflict with my code.
