What is the distance between the two header rows on -12?
Posted: Sun May 03, 2015 10:58 pm
The ESP-8266-12 module has two 8-pin headers rows with 2mm pitch.
But I can't find any documentation of the distance between those header rows.
The width of the entire PCB seems to be 16mm from various data sheets I've found.
But the distance between the hole rows is not set out.
Eye-balling it, i seems like 15mm (1mm in from each side) but this could easily be off.
Does anyone know for sure? Is there some open source breakout/mount board for this module where I can measure the distance?
