Here you will find my SDK code samples, Arduino IDE code samples and libraries.
Arduino IDE code samples for ESP8266 boards:
Following examples are intended to be used with the Arduino IDE from https://github.com/esp8266/arduino which supports ESP8266 boards.
Arduino IDE samples/ESP_MCP3201_SPI/ - Demo of SPI communication of an AD converter MCP3201 with the ESP8266 board
Arduino IDE Libraries for ESP8266 boards:
ESP_SSD1306 - SSD1306 display library for ESP8266 boards (Arduino IDE) (Adafruit_SSD1306 mod) Check https://github.com/somhi/ESP_SSD1306
ESP_SerialLCD - Serial LCD driver Library for the ESP8266 (Arduino IDE) Check https://github.com/somhi/ESP_SerialLCD
SDK code samples:
When I started programming the ESP8266 with the Espressif SDK I had no clue of where to start with. I took the basic_example from https://github.com/esp8266/source-code-examples but without any code comment it was meaningless to me. After reading this article http://www.penninkhof.com/2015/03/how-t ... n-esp8266/ and gathering some other info I enriched the basic example with my own comments. Hope this helps a little bit to the beginners like me.
Following examples were tested with the Espressif SDK:
SDK samples/basicApp_0.1/ - Connects as a wifi station to a router AP, Sends 'Hello' to the serial port
SDK samples/basicApp+SPI_0.2/ - Added SPI support to receive data from and A/D SPI converter (MCP3201) (Uses SPI driver library from https://github.com/MetalPhreak/ESP8266_SPI_Driver)
Regards.
