using this tutorial: https://www.ukhas.net/wiki/esp8266_firmware_update
for OS X
I downloaded the first bin file successfully, then it bricked my device.
I'm using an ESP-1 and the firmware version before was 0018000902-AI03.
Explore... Chat... Share...
Connect your ESP8266 module as follows:
Vcc = 3.3V (needs around 300-400mA peak)
Gnd = -ve ground
CH_PD = Chip enable so always +ve
RST = Leave floating or ground to reset
GPIO0 = Normally floating but this needs to be grounded when you start the update.
UTXD = Tx data connect to Txd on FTDI/Serial interface
URXD = Rx data connect to Rx of FTDI/Serial interface
