MEM CHECK FAIL!!!However, it still joins AP and acquires an IP address. No ill effects other than the nasty message have been observed so far. Anybody seen this?
PS. Is there a way to turn off auto-joining previously used AP?
Explore... Chat... Share...
MEM CHECK FAIL!!!esp03madness wrote:About auto-join:
Awesome, thanks for the pointer. I wonder - if one turns off the auto join, does the ESP still store the relevant data (SSID, pass) in the flash? Cause it really shouldn't...
