By fcspiteri
#20110 Hi there.
I just successfully flashed my ESP-01 with
Code: Select allnodemcu_lastest.bin
using
Code: Select allespytool.py
Now I want to send AT commands.
After flashing, I unpowered, removed connection to GPIO0, and repowered.
I tried
Code: Select allscreen /dev/ttyUSB0 9600
and it takes me to a blank terminal. I try to type, and nothing shows up. I tried baud rates of
Code: Select all57600
and
Code: Select all115200
, but neither of those worked either. On all three baud rates, when I cycle power, I get some jibberish question mark things in the terminal.
Anyone have an idea of what my problem might be?
By tytower
#20204 When the chip fires up it shoots out some stuff on 75800 baud or thereabouts . Then it switches to another baud rate which on my modules is 115200. Thats probably what you are seeing . Change to 75800 and have a look . It might be continually resetting.
By fcspiteri
#20226 Thanks for the suggestion. I tried that baud rate, and lots of others. They're all yielding the same results.
[code]�<Վ���8�
���8����<Y����<��
[/code]
To confirm, I'm using a USB-TTy cable. I have the following connections:
USB GND -> GND
USB RX -> ESP TX
USB TX -> ESP RX
+3.3V -> ESP VCC
GND -> ESP GND
+3.3V -> ESP CH_PD
I've also tried connecting ESP RESET to +3.3V (HIGH).
Any other suggestions?
By tytower
#20230 I'm not familiar with a "USB-TTy" Is that the same as an FTDI cable?Mine was putting out 4.76 Volts I found so I should have had a 3.3V one . Used a couple of diodes in series to drop it .
Your connections look right but I'll stick my note on the ESP12 in here just in case . When you flash GPIO0 is kept low and when running High or floating but I notice mine keeps running after loading until a reset occurs.
Actually someone else quoted that frequency as 74800 or so . try that then you might have to look it up for the right one . I'll come back and edit it when I can. User cal says
The boot code uses 74880/115200 until the firmware sets otherwis...
