Communication with ESP seems fine however I get "Invalid"
PostPosted: Sun Jun 14, 2015 3:09 pm
by Tom91_UK
Wiring:
ESP8266 connected to 3.3V external supply. RX+TX connected to bi-directional level shifter 3.3 <> 5.5V to Arduino.
Screenshot of Basic communication:
CWJAP is obviously fail, but I think there is something to do with communication settings itself. all other baud rates wouldn't work apart from 115200, however I can't find why my ESP CIOBAUD? shows an error when trying to get that information.
What are possibly causes for that?
Thanks,
Tom
Re: Communication with ESP seems fine however I get "Invalid
PostPosted: Tue Jun 16, 2015 8:07 am
by sfyffe
Hi Tom,
Depending on your version of firmware you may need to use this to change the baud rate:
AT+IPR=9600
The busy p is normal if the module is blocked on a prior command. You will need to build into your code a wait\retry logic or do a hard reset on the power. Really, by the time you get the correct process down then the module behaves as it should and you rarely ever see busy returns.
Stephen
