Reg: Unable to connect ESP8266
Posted: Tue Jun 16, 2015 12:49 pm
Hi There,
Currently i'm working with EP8266 ESP-12 Module.
Yesterday i thought of loading pre compiled binaries to flash to connect wifi router ( eagle.flash.bin & eagle.irom0text.bin)
i will let you know steps followed & kindly help on this..
Environment: WINDOWS VISTA, Python2.x, ESPTool
1) i played command "esptool.py -p COM5 flash_id" .. then i got "Manufacturer : C8, Device: 4016"
2) i played command "esptool.py -p COM5 write_flash 0x00000 eagle.flash.bin 0x40000 eagle.irom0text.bin" .. then i got "invalid packet exception" .
3) i played command "esptool.py -p COM5 flash_id" .. then i got below output
4) Now, i thought of using AT command to reset the ESP8266.. i used many serial monitor softwares (realterm, arduino, sscomm32E, Terminal, accessport etc..)
5) i made "AT" command .. no response in return.. i tried "AT+RST" command no response in return..
Now i'm clueless .. can somebody help me out by answer below questions
1) how can i reset my device ( factory settings ) ?
2) how to load my precompiled binary files to flash ?
Thanks in advance & have a great day.
Cheers.
Connecting...
File "D:\esptool-master\esptool.py", line 482, in <module>
esp.connect()
File "D:\esptool-master\esptool.py", line 158, in connect
raise Exception('Failed to connect')
Exception: Failed to connect
Cheers.
