Connectivity to hotspots
Posted: Mon Jul 06, 2015 5:15 am
Hi, could you help me out a bit? My Esp seem to be sending out data perfectly while connected to my home router. However, the connection closes most of the time when I use a wifi hotspot instead, and most of the values dont send. This is really weird because it works beautifully with my home wifi. My wifi hotspot works fine by the way and I've tried using different hotspots. Some values do get across though, but these are far and few.
Basically, the connection gets terminated after every value the module is trying to send, which means there's probably an error in the AT+CIPSEND that comes up when using a hotspot for some reason.
