Here's my initial setup:
VCC - 3.3 V on Arduino
RST - nothing
CH_PD - 3.3 V on Arduino
TX - RX on Arduino (TX is transmitting data to RX, so I don't need a voltage divider, right?)
RX - voltage divider (R1 = 10K, R2 = 20K) - TX on Arduino
GPIO0 - GND on Arduino
GPIO2 - nothing
GND - GND on Arduino
Then I tried uploading a sketch from the Arduino IDE and got the following error:
warning: espcomm_sync failed
error: espcomm_open failed
After trying different IDEs, programmers, serial port I tried firmware flashers to at least see if I can communicate with it. NodeMCU for example just
showed "Waiting MAC" with GPIO0 to ground and without.
I also tried connecting TX to TX and RX to RX but got the same results. Tried connecting RX through a voltage divider as well.
With this setup the blue led was constantly on. I remembered reading somewhere that that could happen due to insufficient power supply,
so I also tried connecting both pins without the voltage dividers (the blue led is still blinking after the power up so hopefully I didn't burn them).
I also tried connecting GPIO0 to 3.3V and not connecting it to anything at all, connecting RST to 3.3V, connecting GPIO2 to ground as well.
On Mega there are 4 sets of TX and RX pins, so I tried them all out TX/RX0,1,2 and 3.
Still no idea what's going on
