- Wed Nov 05, 2014 4:23 am
#2259
Fadi wrote:Getting that same problem as well.
UPDATE: Ok so after a bit more testing, I left GPIO2 floating!
(although https://github.com/esp8266/esp8266-wiki/wiki/Uploading states it should be HIGH)
and was able to get the firmware onto there.
I've got the same problem on my Mac and on the VM
Code: Select allmac-mini-van-gerard:Documents gerard$ sudo ./esptool.py --port /dev/cu.usbserial read_mem 0
Connecting...
Traceback (most recent call last):
File "./esptool.py", line 322, in <module>
print '0x%08x = 0x%08x' % (args.address, esp.read_reg(args.address))
File "./esptool.py", line 140, in read_reg
res = self.command(ESPROM.ESP_READ_REG, struct.pack('<I', addr))
File "./esptool.py", line 102, in command
raise Exception('Invalid head of packet')
Exception: Invalid head of packet
mac-mini-van-gerard:Documents gerard$ Code: Select allesp8266@esp8266-VirtualBox:~$ sudo esptool.py --port /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller-if00-port0 read_mem 0
Connecting...
File "/usr/bin/esptool.py", line 322, in <module>
File "/usr/bin/esptool.py", line 140, in read_reg
File "/usr/bin/esptool.py", line 102, in command
Exception: Invalid head of packet I have experimented with GPIO2 as Fadi suggests:
- GPIO2=FLOAT "Invalid head of packet"
- GPIO2=HIGH "Failed to connect"
- GPIO2=LOW "Failed to connect"
I have RESET the ESP between tests.
After reconnecting the module still responds to AT commands. Firmware version reported via AT_GMR is 00160901.
So my result differs from Fadi here.
Could this be caused by the older FW version, or anyone with other suggestions, please?
