I make a dev env that reuse modules more easy, with OTA works in simple way.
Firmware code: https://github.com/nqd/esp8266-dev
Tested server: http://103.253.146.183/, code https://github.com/ubisen/ota-update
Happy coding.
Explore... Chat... Share...
