In our current product prototype we want to interface 6 Digit 7 segment display. The display is based on TM1637 display driver. TM1637 display driver use I2C for communication and I'm using GPIO 0 ( SCL ) and 2 ( SDA ) of ESP for communication.
Problem I'm facing is after sending START bytes to TM1637 Display driver I'm not able to get acknowledgement signal on GPIO2. Display is working fine with other development board with same logic. I also attach Code and TM1637 display driver's datasheet for a reference.
Any one have Idea where I'm wrong ? Is there any problem with GPIO initialization ?
Please help me !
Thanks & regards,
Prakash
#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "tm1637.h"
#include "tm1637font.h"
/* i2c Methods for handling data transfer to and from the tm1637. */
void ICACHE_FLASH_ATTR delay_us( uint8_t i )
for( ; i>0; i-- );
* FunctionName :
* Description :
* Parameters : NONE
* Returns : NONE
void ICACHE_FLASH_ATTR i2c_start(void)
os_printf("i2c_start - IN \n");
I2C_MASTER_SCL_HIGH( );
I2C_MASTER_SDA_HIGH( );
delay_us(2);
I2C_MASTER_SDA_LOW( );
os_printf("i2c_start - OUT \n");
* FunctionName :
* Description :
* Parameters : NONE
* Returns : NONE
void ICACHE_FLASH_ATTR i2c_ack (void)
uint8 ret = 0;
os_printf("i2c_ack - IN \n");
I2C_MASTER_SCL_LOW( );
delay_us (5);
PIN_PULLUP_EN( I2C_MASTER_SDA_MUX ); // enable pin PULL-UP
GPIO_DIS_OUTPUT( GPIO_ID_PIN( I2C_MASTER_SDA_GPIO )); // set I2C_MASTER_SDA_GPIO as input
while( 1 )
ret = GPIO_INPUT_GET( GPIO_ID_PIN( I2C_MASTER_SDA_GPIO ) );
os_printf("- %d ", ret);
if(ret)
break;
I2C_MASTER_SCL_HIGH();
delay_us( 2 );
I2C_MASTER_SCL_LOW();
os_printf("i2c_ack - OUT \n");
* FunctionName :
* Description :
* Parameters : NONE
* Returns : NONE
void ICACHE_FLASH_ATTR i2c_stop (void)
os_printf("i2c_stop - IN \n");
delay_us (2);
I2C_MASTER_SDA_LOW();
delay_us (2);
delay_us (2);
I2C_MASTER_SDA_HIGH();
os_printf("i2c_stop - OUT \n");
* FunctionName :
* Description :
* Parameters : NONE
* Returns : NONE
void ICACHE_FLASH_ATTR i2c_write ( uint8_t oneByte )
uint8_t i;
os_printf("i2c_write - IN\n");
for (i=0; i<8; i++)
( oneByte & 0x01 ) ? I2C_MASTER_SDA_HIGH() : I2C_MASTER_SDA_LOW();
delay_us (3);
oneByte = oneByte >> 1;
delay_us (3);
os_printf("i2c_write - OUT \n");
* FunctionName : i2c_master_gpio_init
* Description :
* Parameters : NONE
* Returns : NONE
i2c_master_gpio_init(void)
os_printf("\ni2c_master_gpio_init - IN\n");
ETS_GPIO_INTR_DISABLE() ;
PIN_FUNC_SELECT( I2C_MASTER_SDA_MUX,
I2C_MASTER_SDA_FUNC
PIN_FUNC_SELECT( I2C_MASTER_SCL_MUX,
I2C_MASTER_SCL_FUNC
ETS_GPIO_INTR_ENABLE() ;
GPIO_OUTPUT_SET(GPIO_ID_PIN( I2C_MASTER_SDA_GPIO ), 0); // set I2C_MASTER_SDA_GPIO as Low-level output
GPIO_OUTPUT_SET( GPIO_ID_PIN( I2C_MASTER_SCL_GPIO ), 0); // set I2C_MASTER_SDA_GPIO as Low-level output
os_printf("i2c_master_gpio_init - OUT\n");
* FunctionName :
* Description :
* Parameters : NONE
* Returns : NONE
void ICACHE_FLASH_ATTR display( void )
int i;
i2c_start();
i2c_write( 0x40 );
i2c_ack();
i2c_stop();
i2c_start();
i2c_write( 0xC0 ); // Set the starting address
i2c_ack();
for( i = 1; i <= TM1637_DIGITS; i++ )
i2c_write( 0xff );
i2c_ack( );
i2c_stop();
i2c_start();
i2c_write( 0x8F );
i2c_ack();
i2c_stop();
here is a macro definitions :
#ifndef __tm1637_H__
#define __tm1637_H__
void i2c_master_gpio_init( void );
void display( void );
#define I2C_MASTER_SDA_MUX PERIPHS_IO_MUX_GPIO2_U
#define I2C_MASTER_SCL_MUX PERIPHS_IO_MUX_GPIO0_U
#define I2C_MASTER_SDA_GPIO 2
#define I2C_MASTER_SCL_GPIO 0
#define I2C_MASTER_SDA_FUNC FUNC_GPIO2
#define I2C_MASTER_SCL_FUNC FUNC_GPIO0
#define I2C_MASTER_SCL_LOW( ) \
GPIO_OUTPUT_SET(GPIO_ID_PIN( I2C_MASTER_SCL_GPIO ), 0 )
#define I2C_MASTER_SCL_HIGH( ) \
GPIO_OUTPUT_SET(GPIO_ID_PIN( I2C_MASTER_SCL_GPIO ), 1 )
#define I2C_MASTER_SDA_LOW( ) \
GPIO_OUTPUT_SET(GPIO_ID_PIN( I2C_MASTER_SDA_GPIO ), 0 )
#define I2C_MASTER_SDA_HIGH( ) \
GPIO_OUTPUT_SET(GPIO_ID_PIN( I2C_MASTER_SDA_GPIO ), 1 )
#define TM1637_DIGITS 6
#endif
