// reset WiFi module
wifi.println("AT+RST");
// 500ms delay followed by reading the result
wifi.println("AT+CWMODE=1");
wifi.println("AT+CWJAP=\"accesspoint\",\"password\"");
wifi.println("AT+CIPSTART=\"UDP\",\"10.0.1.100\",\"34807\"");
int v;
if (currentMillis - previousMillis >= interval) {
rs232.print("Sending beacon: ");
char *data = "Beacon,10.0.1.57,8080";
int bytes = strlen(data);
wifi.print("AT+CIPSEND=");
wifi.println(bytes);
wifi.println(data);
wifi.println("AT+CIPCLOSE");
while(wifi.available() > 0) {
v = Serial.read();
if (v == 10) {
wb[wctr] = 0;
wctr = 0;
rs232.println(wb);
} else if (v == 13) {
// gndn
} else {
wb[wctr] = v;
wctr++;
}And here's what I get back:
AT+CIPSEND=23
> MyBeacon,10.0.1.57,8080AT+CIPCLOSE
busy s...
busy s...
SEND OKNothing ever arrives at the destination. I've tested the server with code running on other systems and it works fine, so I'm guessing something is going wrong with my ESP-8266. Any suggestions or clues?
Thanks!
