Esptool.py improvements
PostPosted: Mon Nov 10, 2014 11:02 am
by terminator
Hi, I added small fix to esptool.py that fixes failed to leave flash mode, not sure how it works though. Also merged auto resetting module before flashing from other repository but I can't find it now :/
https://github.com/toomasz/esp8266_stuff
I would like to add more improvements to esptool. Does anyone know if its possible to change baud rate of serial during firmware uploading? 115200 is fine but i want to make it faster.
Re: Esptool.py improvements
PostPosted: Mon Nov 10, 2014 1:05 pm
by igrr
Yes, you can change the baud rate defined in esptool.py. Bootloader will do autodetection. I'm flashing at 500k with fairly short cables.
PostPosted: Tue Nov 11, 2014 3:49 pm
by wolvie
Thanks terminator. That's working brilliantly... manual resetting and failure to leave flash mode was getting to be a real PITA. Cheers.
