Then i am trying to create TCP. I could see that only if i enable multiple connections, i can then later create TCP connection to Amazon server, but with a single connection i cant !
So this let me to create the TCP latter :
if (wifi.enableMUX())
Serial.print("multiple ok\r\n");
but this is not :
if (wifi.disableMUX()) {
Serial.print("single ok\r\n");
the tcp connection is made with :
uint8_t buffer[128] = {0};
static uint8_t mux_id = 0;
if (wifi.createTCP(mux_id, HOST_NAME, HOST_PORT)) {
Serial.print("create tcp ");Which as said works only for multiple (why ? )
Then , the GET request which works in any browser and get tool, but is not working on the esp (when the TCP connection returns true) :
char *hello = "GET /index.php HTTP/1.1\r\nHost:52.xx.2xx.xx\r\nUser-Agent:runscope/0.1\r\nContent-Type:application/json\r\nConnection:close\r\n\r\n";
Serial.println(hello);
wifi.send((const uint8_t*)hello, strlen(hello));
uint32_t len = wifi.recv(buffer, sizeof(buffer), 10000);
if (len > 0) {
Serial.print("Received:[");
What is going on here?
What is the difference between multi to single ?
Is there a difference for the mux_id channel being 0 in the TCP connection ?
Thanks a lot !
//library
http://docs.iteadstudio.com/ITEADLIB_Ar ... index.html
