esp-03 modules, no uart comms no matter what
Posted: Tue Oct 20, 2015 1:22 pm
hi,
i have finally got round to attempting to play with my esp modules.
i have a pair of esp 03 modules and after spending the better part of the last few hours going through this site and many many different things to try from google im stumped.
i have an ftdi adapter that definately works and i can chuck it straight on my microchip pic and send/recieve serial data no problem so i know that is fine.
i have tried my modules as specced by others success with them by having my connections :
gnd - gnd
vcc - 3.3v ( 1A capable )
ch_pd to vcc via 2.2k res
gpio 0 - gnd
gpio 15- gnd
ftdi tx - esp rx
ftdi rx - esp tx
i have set my ftdi to 9600 and 115200 as well as swapping my tx/rx lines and even trying gpio2 to vcc as some have stated is needed but regardless i get absolutely nothing at all,i cant even get the uart to connect to flash it in any way
my soldering of the wire to each pad is good and clean with a solid connection to each pin used but i am getting knowwhere and its just becoming so frustrating as their seems to be so much contradicting information at times for the same module that it just gets ridiculous.
i bought these from an ebay sellr survy, so either they do not come flashed and i cant get them to even connect or that seller may be selling a few bricked ones but so far i have not found anyone saying they have used that seller and they dont work.
so im stuck good now, i cant flash it, i cant connect it and now i need to find some at commands to try but honestly if the uart wont even connect then im not really holding my breath on that one.
well i finally ended up calling it quits on this for the night at about 4am, i even had gpio 16 pulled hi/low / sideways as some posts i gfind on the net seem to say that needs to be pulled high.
so im stuck with modules that dont even seem to connect to the uart so what now? id like to try a few more things if others have ideas before i commission these things to the garbage, seems to be too many issues with these just for trying to communicate with it
tony
gnd - gnd
gpio 0 - gnd
gpio 15- gnd
ftdi tx - esp rx
ftdi rx - esp tx
tony
