How to add the mDNS is RTOS SDK?
PostPosted: Tue Nov 03, 2015 3:43 am
by march_seven
Hi ,all
does anybody success adding mdns in ESP8266 RTOS SDK???
how could we achieve it ????
i have found a linux example which using a socket。
but i don't know how to change it as a task in ESP8266
Code: Select all#include <stdlib.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <netdb.h>
#include <stdio.h>
#include <unistd.h>
#include <string.h>
#define PORT 53
#define MSG_SIZE 512
void usage(const char* prog)
  fprintf(stderr,"Usage: %s IP1 IP2 IP3 IP4\n",prog);
  fprintf(stderr,"Example:\n   %s 192 168 1 1\n",prog);
  fprintf(stderr,"Fake DNS returning the same IP address for any DNS request.\n");
int main(int argc, char *argv[])
  struct sockaddr_in addr, server;
  char msg[MSG_SIZE];
  if(argc!=5)
      usage(argv[0]);
      return 1;
  int ip1=atoi(argv[1]);
  int ip2=atoi(argv[2]);
  int ip3=atoi(argv[3]);
  int ip4=atoi(argv[4]);
  if(ip1<0||ip1>255||ip2<0||ip2>255||
     ip3<0||ip3>255||ip4<0||ip4>255) {
      usage(argv[0]);
      return 1;
  // socket creation
  int sd=socket(AF_INET, SOCK_DGRAM, 0);
  if(sd<0) {
    fprintf(stderr,"%s: cannot open socket \n",argv[0]);
    return 1;
  // bind local server port
  server.sin_family = AF_INET;
  server.sin_addr.s_addr = htonl(INADDR_ANY);
  server.sin_port = htons(PORT);
  int rc = bind (sd, (struct sockaddr *) &server,sizeof(server));
  if(rc<0) {
    fprintf(stderr,"%s: cannot bind port number %d \n",
      argv[0], PORT);
    return 1;
  int len = sizeof(addr);
  int flags=0;
  while(1) {
    // receive message
    int n = recvfrom(sd, msg, MSG_SIZE, flags,
       (struct sockaddr *) &addr, &len);
    if(n<0) {continue;}
    // Same Id
    msg[2]=0x81;msg[3]=0x80; // Change Opcode and flags
    msg[6]=0;msg[7]=1; // One answer
    msg[8]=0;msg[9]=0; // NSCOUNT
    msg[10]=0;msg[11]=0; // ARCOUNT
    // Keep request in message and add answer
    msg[n++]=0xC0;msg[n++]=0x0C; // Offset to the domain name
    msg[n++]=0x00;msg[n++]=0x01; // Type 1
    msg[n++]=0x00;msg[n++]=0x01; // Class 1
    msg[n++]=0x00;msg[n++]=0x00;msg[n++]=0x00;msg[n++]=0x3c; // TTL
    msg[n++]=0x00;msg[n++]=0x04; // Size --> 4
    msg[n++]=ip1;msg[n++]=ip2;msg[n++]=ip3;msg[n++]=ip4; // IP
    // Send the answer
    sendto(sd,msg,n,flags,(struct sockaddr *)&addr,len);
  ret
