which should need to use strncasecmp() and stroul ()
but when complies ,it shows me a error that those function have not defined。
br!
Explore... Chat... Share...
bbx10node wrote:If you are using the Arduino IDE, strtoul is available using the staging version.
https://github.com/esp8266/arduino#staging-version-
If strncasecmp is available in the IDE for the Uno but is not available for the ESP8266, I suggest reporting this as a bug over at https://github.com/esp8266/arduino.
