By alex_g
#34067 Hi Everybody,
Just started off with NodeMCU, and on the whole I'm very pleased, everything seems to be working fine. I know that, because I tested it using my mobile phone as a hotspot to make a small WLAN.
I ran the primer example with the switching on and off of the two LEDS, no problems.
HOWEVER... the reason I used my phone to make up a WLAN was that I could not log on to my normal wifi, despite all my efforts. In fact, for a while I thought the board might be broken, before I had the thought of using the phone as an AP.
My normal wifi setup has one of those old type 5-byte passwords, rather than a normal random string. I think this may be the problem. (Sorry about my clueless use of wifi nomenclature)
Assuming the password is "A1B2C3D4E5", I tried enetering it as above, to no effect.
I also tried converting to bytes, so that, eg. for the above example I'd have "\161\178\195\212\229", again nothing. No - actually I got back a little protest string "stdin:1: pwd:0,8~64". Not sure what that's about, I think it may have objected to the binary in the string.
In the end, out of desparation I even tried silly strings like "A1-B2-C3-D4-E5", all to no avail.
Any ideas, suggestions, illuminations most appreciated.
Thanks
NodeMCU 0.9
Flash: 20150704 (Lua 5.1)
Linux terminal running "screen" as per most of the tutorials out there.
