Hardware abstraction
PostPosted: Sat Nov 21, 2015 1:00 pm
by duparq
I've begun to port HWA to ESP8266. HWA is a set of C macro definitions that provide an object-oriented description of the hardware of a device, ad-hoc polymorphism and instructions that accept a variable length of arguments.
I am only at the beginning but there is an example of what it looks like in action (I need to be able to put TXD low for some time while another micro-controller leaves the reset state):
#include <hwa/modules/esp-wroom-02.h>
#define LED             hw_pin_gpio5
#define IROM            __attribute__((section (".irom.text")))
#define IRAM
/*  Function called every 10 ms
 *   * toggle the LED on/off every 200 ms
 *   * when the LED is turned on, turn TXD low for 100 ms
 *   * when the LED if turned off, send "ON\n" on TXD
void IROM every10ms ( )
  static uint8_t        count ;
  static uint8_t        txdlow ;
  if ( txdlow ) {
    txdlow-- ;
    if ( txdlow == 0 )
       *  TXD has been set low for 100 ms. Release it now: connect pin GPIO1 to
       *  the TXD signal
      hw_config( hw_pin_gpio1, function, hw_uart0_txd );
  count++ ;
  if ( count < 20 )
    return ;
  /*  The following is done once every 200 ms
  count = 0 ;
  if ( hw_read( LED ) == 0 ) {
     *  Turn LED on
    hw_write( LED, 1 );
     *  Turn TXD low for 100 ms: connect pin GPIO1 to the GPIO1 signal
    txdlow = 10 ;
    hw_config( hw_pin_gpio1, function, gpio );
  else {
     *  Turn LED off
    hw_write( LED, 0 );
     *  Send message
    os_printf("ON\n");
void IROM user_init()
  hw_config( LED,
             function,  gpio,                   // Optionnal
             direction, output_when_awake
  /*  Pin GPIO1 is also used as pin TXD of hw_uart0
   *  We want a low level on that pin when used as a GPIO
             direction,    output );
  hw_write( hw_pin_gpio1, 0 );
  /*  Configure the UART
   *    Note: the OS has already configured the RXD and TXD pins
  hw_config( hw_uart0,
             baudrate,    9600,
             databits,    8,
             parity,      none,
             stopbits,    1,
             /* pin_txd,     hw_pin_gpio1, */
             /* pin_rxd,     hw_pin_gpio3, */
  os_printf("Hello World!\n");
  /*  Trigger a function call every 10 ms (about)
  static os_timer_t timer ;
  os_timer_disarm( &timer );
  os_timer_setfn( &timer, (os_timer_func_t *)every10ms, NULL );
  os_timer_arm( &timer, 10, 1 );
Some documentation and a bunch of gradually elaborate examples for Atmel AVRs here. The source is hosted on Github (the ESP8266 branch is not pushed yet).
Re: Hardware abstraction
PostPosted: Sat Nov 21, 2015 1:05 pm
by duparq
I submitted too early...
Any comment or suggestion is welcome!
