Seems like the latest staging has a problem with Sprintf
Igrr are you aware of this.
Dans
Explore... Chat... Share...
martinayotte wrote:What kind of problems ?
Because the sprintf in libc_replacements.c is quite simple and simply redirect it to ets_vsprintf() of the Espressif SDK.
Also, I've almost the latest version and don't have any problems.
int32_t getRSSI(const char* target_ssid) {
byte available_networks = WiFi.scanNetworks();
for (int network = 0; network < available_networks; network++) {
if (strcmp(WiFi.SSID(network), target_ssid) == 0) {
return WiFi.RSSI(network);
return 0;
} if (strcmp(WiFi.SSID(network).c_str(), target_ssid) == 0) {
