https://hackaday.io/project/2879-esp8266-wifi-module-library#j-discussion-11305
Fix appears to be
The fix is AT+CWJAP="","" and then power cycle the boardRead the post by moxhamj under Discussions
Explore... Chat... Share...
The fix is AT+CWJAP="","" and then power cycle the boardIt takes about 20-25 seconds for home assistant c[…]
